Computational RNA secondary structure design: empirical complexity and improved methods, BMC Bioinformatics, vol.8, issue.1, p.34, 2007. ,
DOI : 10.1186/1471-2105-8-34
RNAexinv: An extended inverse RNA folding from shape and physical attributes to sequences, BMC Bioinformatics, vol.12, issue.1, p.319, 2011. ,
DOI : 10.1016/0303-2647(95)01568-X
INFO-RNA--a fast approach to inverse RNA folding, Bioinformatics, vol.22, issue.15, pp.1823-1854, 2006. ,
DOI : 10.1093/bioinformatics/btl194
rnaDesign: Local search for RNA secondary structure design, 2009 IEEE Symposium on Computational Intelligence in Bioinformatics and Computational Biology, 2009. ,
DOI : 10.1109/CIBCB.2009.4925700
Evolutionary solution for the RNA design problem, Bioinformatics, vol.30, issue.9, pp.1250-1258, 2014. ,
DOI : 10.1093/bioinformatics/btu001
A simple, practical and complete O -time Algorithm for RNA folding using the Four-Russians Speedup, Algorithms for Molecular Biology, vol.36, issue.20, p.13, 2010. ,
DOI : 10.1093/nar/gkn544
RNAiFOLD: A CONSTRAINT PROGRAMMING ALGORITHM FOR RNA INVERSE FOLDING AND MOLECULAR DESIGN, Journal of Bioinformatics and Computational Biology, vol.11, issue.02, p.1350001, 2013. ,
DOI : 10.1142/S0219720013500017
Rfam: an RNA family database, Nucleic Acids Research, vol.31, issue.1, pp.439-441, 2003. ,
DOI : 10.1093/nar/gkg006
Schnelle Faltung und Vergleich von Sekund???rstrukturen von RNA, Monatshefte f???r Chemie Chemical Monthly, vol.157, issue.2, pp.167-188, 1994. ,
DOI : 10.1007/BF00818163
Computational design of RNAs with complex energy landscapes, Biopolymers, issue.12, pp.991124-1136, 2013. ,
DOI : 10.1002/bip.22337
A global sampling approach to designing and reengineering RNA secondary structures, Nucleic Acids Research, vol.40, issue.20, pp.4010041-52, 2012. ,
DOI : 10.1093/nar/gks768
URL : https://hal.archives-ouvertes.fr/hal-00733924
Frnakenstein: multiple target inverse RNA folding, BMC Bioinformatics, vol.13, issue.1, p.260, 2012. ,
DOI : 10.1093/nar/gkg068
Expanded sequence dependence of thermodynamic parameters improves prediction of RNA secondary structure, Journal of Molecular Biology, vol.288, issue.5, pp.911-940, 1999. ,
DOI : 10.1006/jmbi.1999.2700
Fast algorithm for predicting the secondary structure of single-stranded RNA., Proceedings of the National Academy of Sciences, vol.77, issue.11, pp.6903-6916, 1980. ,
DOI : 10.1073/pnas.77.11.6309
A weighted sampling algorithm for the design of RNA sequences with targeted secondary structure and nucleotide distribution, Bioinformatics, vol.29, issue.13, pp.29-308, 2013. ,
DOI : 10.1093/bioinformatics/btt217
URL : https://hal.archives-ouvertes.fr/hal-00840260
Full Design Automation of Multi-State RNA Devices to Program Gene Expression Using Energy-Based Optimization, PLoS Computational Biology, vol.220, issue.8, p.1003172, 2013. ,
DOI : 10.1371/journal.pcbi.1003172.s009
Inverting the Viterbi algorithm, Proceedings of the 25th international conference on Machine learning, ICML '08, pp.904-911, 2008. ,
DOI : 10.1145/1390156.1390270
A modular strategy for engineering orthogonal chimeric RNA transcription regulators, Nucleic Acids Research, vol.41, issue.15, pp.7577-7588, 2013. ,
DOI : 10.1093/nar/gkt452
MODENA: a multi-objective RNA inverse folding, Advances and Applications in Bioinformatics and Chemistry, vol.4, pp.1-12, 2011. ,
DOI : 10.2147/AABC.S14335
NNDB: the nearest neighbor parameter database for predicting stability of nucleic acid secondary structure, Nucleic Acids Research, vol.38, issue.Database, pp.280-282, 2010. ,
DOI : 10.1093/nar/gkp892
RNAi Therapies: Drugging the Undruggable, Science Translational Medicine, vol.6, issue.240, pp.240-247, 2014. ,
DOI : 10.1126/scitranslmed.3008362
Nucleic acid sequence design via efficient ensemble defect optimization, Journal of Computational Chemistry, vol.451, issue.3, pp.439-52, 2011. ,
DOI : 10.1002/jcc.21633
Flexible RNA design under structure and sequence constraints using formal languages, Proceedings of the International Conference on Bioinformatics, Computational Biology and Biomedical Informatics, BCB'13, pp.229-238, 2013. ,
DOI : 10.1145/2506583.2506623
URL : https://hal.archives-ouvertes.fr/hal-00823279
Optimal computer folding of large RNA sequences using thermodynamics and auxiliary information, Nucleic Acids Research, vol.9, issue.1, pp.133-148, 1981. ,
DOI : 10.1093/nar/9.1.133
