Linear embeddings of low-dimensional subsets of a Hilbert space to R$^m$ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2015
We consider the problem of embedding a low-dimensional set, M, from an infinite-dimensional Hilbert space, H, to a finite-dimensional space. Defining appropriate random linear projections, we propose two constructions of linear maps that have the restricted isometry property (RIP) on the secant set of M with high probability. The first one is optimal in the sense that it only needs a number of projections essentially proportional to the intrinsic dimension of M to satisfy the RIP. The second one, which is based on a variable density sampling technique, is computationally more efficient, while potentially requiring more measurements.
Fichier non déposé
hal-01116153 , version 1 (26-02-2015)
hal-01116153 , version 2 (08-06-2015)
  • HAL Id : hal-01116153 , version 1
Gilles Puy, Mike E. Davies, Rémi Gribonval. Linear embeddings of low-dimensional subsets of a Hilbert space to R$^m$. [Technical Report] INRIA - IRISA - PANAMA; Institute for Digital Communications (IDCom) - University of Edinburgh. 2015. ⟨hal-01116153v1⟩
289 Consultations
413 Téléchargements
