Journal articles
Capturing nonclassical shocks in nonlinear elastodynamic with a conservative finite volume scheme
Abstract : For a model of nonlinear elastodynamics, we construct a finite volume scheme which is able to capture nonclassical shocks (also called undercompressive shocks). Those shocks verify an entropy inequality but are not admissible in the sense of Liu. They verify a kinetic relation which describes the jump, and keeps an information on the equilibrium between a vanishing dispersion and a vanishing diffusion. The scheme pre-sented here is by construction exact when the initial data is an isolated nonclassical shock. In general, it does not introduce any diffusion near shocks, and hence nonclas-sical solutions are correctly approximated. The method is fully conservative and does not use any shock-tracking mesh. This approach is tested and validated on several test cases. In particular, as the nonclassical shocks are not diffused at all, it is possible to obtain large time asymptotics.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01116582
Contributor : Nina Aguillon Connect in order to contact the contributor
Submitted on : Friday, February 13, 2015 - 4:28:48 PM
Last modification on : Wednesday, November 3, 2021 - 9:51:38 AM
Long-term archiving on: : Thursday, May 14, 2015 - 11:00:38 AM
ReconstructionElastoV2.pdf
Identifiers
Collections
Citation
Nina Aguillon. Capturing nonclassical shocks in nonlinear elastodynamic with a conservative finite volume scheme. Interfaces and Free Boundaries, European Mathematical Society, 2016, 18 (2), pp.137-159. ⟨10.4171/IFB/360⟩. ⟨hal-01116582⟩
Share
Metrics
Record views
91
Files downloads
118
