Pangolin v1.0, a conservative 2-D advection model towards large-scale parallel calculation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Geoscientific Model Development Année : 2015
To exploit the possibilities of parallel comput-ers, we designed a large-scale bidimensional atmospheric advection model named Pangolin. As the basis for a fu-ture chemistry-transport model, a finite-volume approach for advection was chosen to ensure mass preservation and to ease parallelization. To overcome the pole restriction on time steps for a regular latitude–longitude grid, Pangolin uses a quasi-area-preserving reduced latitude–longitude grid. The features of the regular grid are exploited to reduce the mem-ory footprint and enable effective parallel performances. In addition, a custom domain decomposition algorithm is pre-sented. To assess the validity of the advection scheme, its re-sults are compared with state-of-the-art models on algebraic test cases. Finally, parallel performances are shown in terms of strong scaling and confirm the efficient scalability up to a few hundred cores.
gmd-8-205-2015.pdf (4.14 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-01117048 , version 1 (23-09-2021)
Paternité
Alexis Praga, Daniel Cariolle, Luc Giraud. Pangolin v1.0, a conservative 2-D advection model towards large-scale parallel calculation. Geoscientific Model Development, 2015, 8, pp.205 - 220. ⟨10.5194/gmd-8-205-2015⟩. ⟨hal-01117048⟩
257 Consultations
57 Téléchargements
