An efficient translation from a modal μ-calculus over finite trees with converse to tree automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
Louis Jachiet
Pierre Genevès
Nabil Layaïda
We present a direct translation from a sub-logic of µ-calculus to non-deterministic binary automata of finite trees. The logic is an alternation-free modal µ-calculus, restricted to finite trees and where formulae are cycle-free. This logic is expressive enough to encode significant fragments of query languages (such as Regular XPath). The size of the generated automaton (the number of transitions) is bounded by 2^n where n is the size of a Fischer-Ladner closure of the formula. This is an improvement over previous translations in 2^{n^2} . We have implemented our translation. In practice, our prototype effectively decides static analysis problems that were beyond reach, such as the XPath containment problem with DTDs of significant size.
Web
aaai17 (1).pdf (266.86 Ko) Télécharger le fichier
hal-01117830 , version 1 (18-02-2015)
hal-01117830 , version 2 (09-12-2016)
  • HAL Id : hal-01117830 , version 2
Louis Jachiet, Pierre Genevès, Nabil Layaïda. An efficient translation from a modal μ-calculus over finite trees with converse to tree automata. 2016. ⟨hal-01117830v2⟩
342 Consultations
210 Téléchargements
