Urban flood modeling with porous shallow-water equations: a case study of model errors in the presence of anisotropic porosity
Porous shallow-water models (porosity models) simulate urban flood flows orders of magnitude faster than classical shallow-water models due to a re-lately coarse grid and large time step, enabling flood hazard mapping over far greater spatial extents than is possible with classical shallow-water models. Here the errors of both isotropic and anistropic porosity models are exam-ined in the presence of anisotropic porosity, i.e., unevenly spaced obstacles in the cross-flow and along-flow directions, which is common in practical applications. We show that porosity models are affected by three types of errors: (a) structural model error associated with limitations of the shallow-water equations, (b) scale errrors associated with use of a relatively coarse * Tel:
