Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : Digital curve acquisition with a vision system introduces a large amount of degradation. At the same time ‘corners’ convey important visual information. Unfortunately they are found in the same spectral domain as the quantization noise. Low-pass filtering of the curvature function is compared with more sophisticated methods that keep the angles ‘sharp’. An automated inspection is successfully performed, demonstrating the efficiency of a new method.
https://hal.inria.fr/hal-01119236 Contributor : Radu HoraudConnect in order to contact the contributor Submitted on : Wednesday, February 25, 2015 - 10:58:14 AM Last modification on : Wednesday, May 4, 2022 - 12:12:03 PM Long-term archiving on: : Tuesday, May 26, 2015 - 1:30:17 PM
José-Cruz Pineda, Radu Horaud. An improved method for high-curvature detection with applications to automated inspection. Signal Processing, Elsevier, 1983, 5 (2), pp.117-125. ⟨10.1016/0165-1684(83)90018-X⟩. ⟨hal-01119236⟩
