An enthalpy method for convection/diffusion phase change, International Journal for Numerical Methods in Engineering, vol.5, issue.1, pp.271-284, 1987. ,
DOI : 10.1002/nme.1620240119
A comparison of numerical models for one-dimensional Stefan problems, Journal of Computational and Applied Mathematics, vol.192, issue.2, pp.445-459, 2006. ,
DOI : 10.1016/j.cam.2005.04.062
Finite difference solution of one-dimensional Stefan problem with periodic boundary conditions, International Journal of Heat and Mass Transfer, vol.46, issue.15, pp.2911-2916, 2003. ,
DOI : 10.1016/S0017-9310(03)00050-4
Heat conduction with freezing or melting, Appl. Mech. Rev, vol.18, pp.951-959, 1965. ,
Analytical heat Diffusion Theory Tracking of a moving interface during a 2D melting or solidification process from measurements on the solid part only, Wiley. [LUI 68] A. V. LUIKOV Proceedings of the 3 rd World Congress on Intelligent Control and Automation, pp.2240-2243, 1968. ,
Méthodes de volumes finis en maillages variables pour des quations hyperboliques en une dimension Numerical solution of a multidimensional two-phase stefan problem, JNum. Funct. Anal. and Optimiz, vol.8, pp.55-82, 1985. ,
Numerical and experimental investigation of melting and freezing processes in phase change material storage, International Journal of Thermal Sciences, vol.43, issue.3, pp.277-287, 2004. ,
DOI : 10.1016/j.ijthermalsci.2003.07.001
Limitation in the apparent heat capacity formulation for heat transfer with phase change, Proc. Okla. Acad. Sci, vol.67, pp.83-88, 1987. ,
Hemisphere publishing corporation An introduction to computational fluid dynamics: the finite volume method " . Longman Scientific and Technical Time discretization schemes for the Stefan problem in a concentrated capacity Numerical solutionof Time-Dependent advection-diffusion-reaction equations Conduction of Heat in solids, Meccanica, vol.28, pp.121-128, 1959. ,
A Generalized Laplace Transform Technique for Phase-Change Problems, Journal of Heat Transfer, vol.112, issue.2, pp.495-497, 1990. ,
DOI : 10.1115/1.2910406
