Local minimization algorithms for dynamic programming equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Scientific Computing Année : 2016
The numerical realization of the dynamic programming principle for continuous-time optimal control leads to nonlinear Hamilton-Jacobi-Bellman equations which require the minimization of a nonlinear mapping over the set of admissible controls. This minimization is often performed by comparison over a finite number of elements of the control set. In this paper we demonstrate the importance of an accurate realization of these minimization problems and propose algorithms by which this can be achieved effectively. The considered class of equations includes nonsmooth control problems with l1-penalization which lead to sparse controls.
KaliseKroenerKunisch2015.pdf (4.04 Mo) Télécharger le fichier
hal-01120450 , version 1 (25-02-2015)
  • HAL Id : hal-01120450 , version 1
Dante Kalise, Axel Kröner, Karl Kunisch. Local minimization algorithms for dynamic programming equations . SIAM Journal on Scientific Computing, 2016, 38 (3). ⟨hal-01120450⟩
580 Consultations
171 Téléchargements
