A Generalized Mutual Exclusion Problem and Its Algorithm, 2013 42nd International Conference on Parallel Processing, pp.300-309, 2013. ,
DOI : 10.1109/ICPP.2013.39
A dining philosophers algorithm with polynomial response time, Proceedings [1990] 31st Annual Symposium on Foundations of Computer Science, pp.65-74, 1990. ,
DOI : 10.1109/FSCS.1990.89525
A priority dynamics for generalized drinking philosophers, Inf. Process. Lett, vol.79, issue.4, pp.189-195, 2001. ,
Group mutual exclusion in O(log n) RMR, PODC 2010, pp.45-54, 2010. ,
A distributed token-based algorithm for the dynamic resource allocation problem, ACM SIGOPS Operating Systems Review, vol.34, issue.3, pp.60-68, 2000. ,
DOI : 10.1145/506117.506125
A distributed K-mutual exclusion algorithm, Proceedings of 15th International Conference on Distributed Computing Systems, pp.153-160, 1995. ,
DOI : 10.1109/ICDCS.1995.500014
The drinking philosophers problem, ACM Transactions on Programming Languages and Systems, vol.6, issue.4, pp.632-646, 1984. ,
DOI : 10.1145/1780.1804
A new algorithm for k mutual exclusions in distributed systems, Journal of Systems and Software, vol.26, issue.2, pp.179-191, 1994. ,
DOI : 10.1016/0164-1212(94)90087-6
Hierarchical ordering of sequential processes, Acta Informatica, vol.1, issue.2, pp.115-138, 1971. ,
DOI : 10.1007/BF00289519
An efficient solution to the drinking philosophers problem and its extensions, WDAG (Disc), pp.83-93, 1989. ,
DOI : 10.1007/3-540-51687-5_34
Asynchronous group mutual exclusion (extended abstract), Proceedings of the seventeenth annual ACM symposium on Principles of distributed computing , PODC '98, pp.51-60, 1998. ,
DOI : 10.1145/277697.277706
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.39.7562
Time, clocks, and the ordering of events in a distributed system, Communications of the ACM, vol.21, issue.7, pp.558-565, 1978. ,
DOI : 10.1145/359545.359563
Upper bounds for static resource allocation in a distributed system, Journal of Computer and System Sciences, vol.23, issue.2, pp.254-278, 1981. ,
DOI : 10.1016/0022-0000(81)90015-5
Token based solutions to M resources allocation problem, Proceedings of the 1997 ACM symposium on Applied computing , SAC '97, pp.340-344, 1997. ,
DOI : 10.1145/331697.332307
Priority inheritance and ceilings for distributed mutual exclusion, Proceedings 20th IEEE Real-Time Systems Symposium (Cat. No.99CB37054), pp.340-349, 1999. ,
DOI : 10.1109/REAL.1999.818861
Distributed algorithm for K-entries to critical section based on the directed graphs, ACM SIGOPS Operating Systems Review, vol.27, issue.4, pp.67-75, 1993. ,
DOI : 10.1145/163640.163646
How to detect a failure and regenerate the token in the log(n) distributed algorithm for mutual exclusion, WDAG, pp.155-166, 1987. ,
An improvement of the log(n) distributed algorithm for mutual exclusion, ICDCS, pp.371-377, 1987. ,
A distributed algorithm for multiple entries to a critical section, Information Processing Letters, vol.30, issue.4, pp.189-193, 1989. ,
DOI : 10.1016/0020-0190(89)90211-1
A tree-based algorithm for distributed mutual exclusion, ACM Transactions on Computer Systems, vol.7, issue.1, pp.61-77, 1989. ,
DOI : 10.1145/58564.59295
A distributed solution to the k-out of-M resources allocation problem, In ICCI, pp.599-609, 1991. ,
DOI : 10.1007/3-540-54029-6_209
URL : https://hal.archives-ouvertes.fr/inria-00075199
Fair k mutual exclusion algorithm for peer to peer systems, ICDCS, pp.655-662, 2008. ,
A modular algorithm for resource allocation, Distributed Computing, pp.157-168, 1998. ,
DOI : 10.1007/s004460050047
An optimal algorithm for mutual exclusion in computer networks, Communications of the ACM, vol.24, issue.1, pp.9-17, 1981. ,
DOI : 10.1145/358527.358537
Multiple Instance Resource Allocation in Distributed Computing Systems, Journal of Parallel and Distributed Computing, vol.23, issue.1, pp.94-100, 1994. ,
DOI : 10.1006/jpdc.1994.1122
Another distributed algorithm for multiple entries to a critical section, Inf. Process. Lett, vol.41, issue.1, pp.51-57, 1992. ,
Improved algorithms for distributed resource allocation, Proceedings of the seventh annual ACM Symposium on Principles of distributed computing , PODC '88, pp.105-116, 1988. ,
DOI : 10.1145/62546.62567
A distributed mutual exclusion algorithm, ACM Transactions on Computer Systems, vol.3, issue.4, pp.344-349, 1985. ,
DOI : 10.1145/6110.214406
