On asymptotic normality of nonparametric estimate for a stationary pairwise interaction point process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
We prove the asymptotic normality of nonparametric estimator of pairwise interaction function for a stationary pairwise interaction point process characterized by the Papangelou conditional intensity and observed in a bounded window of a sequence of cubes growing up to $\mathbb{R}^d$. Formula for the variance of the resulting estimator can be obtained using Papangelou conditional intensity of the point process. This is a random function satisfying the counterpart of the Georgii-Nguyen-Zessin formula. The proof of the asymptotic normality of the resulting estimator is based on the $m_n$-approximation method in the setting of dependent random fields indexed by $\mathbb{Z}^d$ where $d$ is a positive integer.
asympto-stationnaire-HAL.pdf (220.37 Ko) Télécharger le fichier
hal-01121114 , version 1 (27-02-2015)
hal-01121114 , version 2 (29-04-2015)
hal-01121114 , version 3 (23-03-2016)
  • HAL Id : hal-01121114 , version 3
Nadia Morsli. On asymptotic normality of nonparametric estimate for a stationary pairwise interaction point process. 2015. ⟨hal-01121114v3⟩
268 Consultations
138 Téléchargements
