SPBC: Leveraging the Characteristics of MPI HPC Applications for Scalable Checkpointing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The high failure rate expected for future supercomputers requires the design of new fault tolerant solutions. Most check-pointing protocols are designed to work with any message-passing application but suffer from scalability issues at extreme scale. We take a different approach: We identify a property common to many HPC applications, namely channel-determinism, and introduce a new partial order relation , called always-happens-before relation, between events of such applications. Leveraging these two concepts, we design a protocol that combines an unprecedented set of features. Our protocol called SPBC combines in a hierarchical way coordinated checkpointing and message logging. It is the first protocol that provides failure containment without logging any information reliably apart from process checkpoints , and this, without penalizing recovery performance. Experiments run with a representative set of HPC workloads demonstrate a good performance of our protocol during both, failure-free execution and recovery.
sc2013.pdf (433.12 Ko) Télécharger le fichier
hal-01121951 , version 1 (02-03-2015)
Thomas Ropars, Tatiana Martsinkevitch, Amina Guermouche, André Schiper, Franck Cappello. SPBC: Leveraging the Characteristics of MPI HPC Applications for Scalable Checkpointing. International Conference for High Performance Computing, Networking, Storage and Analysis (SC'13), 2013, Denver, United States. ⟨10.1145/2503210.2503271⟩. ⟨hal-01121951⟩
421 Consultations
170 Téléchargements
