Decomposition of Differential Games - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
This paper provides a decomposition technique for the purpose of simplifying the solution of certain zero-sum differential games. The games considered terminate when the state reaches a target, which can be expressed as the union of a collection of target subsets; the decomposition consists of replacing the original target by each of the target subsets. The value of the original game is then obtained as the lower envelope of the values of the collection of games resulting from the decomposition, which can be much easier to solve than the original game. Criteria are given for the validity of the decomposition. The paper includes examples, illustrating the application of the technique to pursuit/evasion games, where the decomposition arises from considering the interaction of individual pursuer/evader pairs.
1409.4624v1.pdf (452.69 Ko) Télécharger le fichier
hal-01122921 , version 1 (04-03-2015)
Adriano Festa, Richard Vinter. Decomposition of Differential Games. 2014. ⟨hal-01122921⟩
88 Consultations
42 Téléchargements
