COMPUTATION OF AVOIDANCE REGIONS FOR DRIVER ASSISTANCE SYSTEMS BY USING A HAMILTON-JACOBI APPROACH - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We consider the problem of computing safety regions, modeled as nonconvex backward reachable sets, for a nonlinear car collision avoidance model with time-dependent obstacles. The Hamilton-Jacobi-Bellman framework is used. A new formulation of level set functions for obstacle avoidance is given and sufficient conditions for granting the obstacle avoidance on the whole time interval are obtained, even though the conditions are checked only at discrete times. Different scenarios including various road configurations, different geometry of vehicle and obstacles, as well as fixed or moving obstacles, are then studied and computed. Computations involve solving nonlinear partial differential equations of up to five space dimensions plus time with nonsmooth obstacle representations, and an efficient solver is used to this end. A comparison with a direct optimal control approach is also done for one of the examples.
main_10nov2017.pdf (1.85 Mo) Télécharger le fichier
hal-01123490 , version 1 (05-03-2015)
hal-01123490 , version 2 (11-11-2017)
hal-01123490 , version 3 (27-11-2019)
  • HAL Id : hal-01123490 , version 2
Ilaria Xausa, Robert Baier, Olivier Bokanowski, Matthias Gerdts. COMPUTATION OF AVOIDANCE REGIONS FOR DRIVER ASSISTANCE SYSTEMS BY USING A HAMILTON-JACOBI APPROACH. 2017. ⟨hal-01123490v2⟩
905 Consultations
441 Téléchargements
