Circular and linear magnetic birefringences in xenon at $\lambda = 1064$ nm
The circular and linear magnetic birefringences corresponding to the Faraday and the Cotton-Mouton effects, respectively, have been measured in xenon at $\lambda = 1064$ nm. The experimental setup is based on time dependent magnetic fields and a high finesse Fabry-Perot cavity. Our value of the Faraday effect is the first measurement at this wavelength. It is compared to theoretical predictions. Our uncertainty of a few percent yields an agreement at better than 1$\sigma$ with the computational estimate when relativistic effects are taken into account. Concerning the Cotton-Mouton effect, our measurement, the second ever published at $\lambda = 1064$ nm, agrees at better than $1\sigma$ with theoretical predictions. We also compare our error budget with those established for other experimental published values.
Optique [physics.optics]
