Enriching the phraseological coverage of??high-frequency adverbs in English-French bilingual dictionaries, Advances in Corpus-Based Contrastive Linguistics: Studies in Honour of Stig Johansson, p.164, 2013. ,
DOI : 10.1075/scl.54.10gra
Les constructions adjectivales en français (Adjectival Constructions in French) (Geneva: Droz, p.114, 1978. ,
Les constructions adjectivales en français (Adjectival Constructions in French) (Geneva: Droz, p.107, 1978. ,
Sentential Complementation of Adjectives in French Adjectives: Formal Analysis in Syntax and Semantics, p.285, 2010. ,
Sentential Complementation of Adjectives in French Adjectives: Formal Analysis in Syntax and Semantics, p.286, 2010. ,
La structure des phrases simples en français: constructions intransitives (The Structure of Simple Sentences in French: Intransitive Constructions) (Geneva: Droz, 1976), 378; Alain Guillet and Christian Leclère, La structure des phrases simples en français: Les constructions transitives locatives (The Structure of Simple Sentences in French: Transitive Locative Constructions), p.446, 1992. ,
Review of the Book Constructions at Work: The Nature of Generalization in Language by Even when they use these methods, linguists adopting them have little use for, and rarely acknowledge, structural and distributional linguistics. &larrhk, Linguistic Typology, vol.12, p.157, 2008. ,
Sentential Complementation of Adjectives in French Adjectives: Formal Analysis in Syntax and Use our professional PDF creation service at http://www.htm2pdf.co.uk! Semantics, Patricia Cabredo Hofherr and Ora Matushansky, pp.285-86, 2010. ,
Establishing the Upper Bound and Inter-Judge Agreement of a Verb Classification Task, Proceedings of LREC, (European Language Resources Association (ELRA), pp.659-64, 2000. ,
[In the 2000s] I began to realize that we theoretical linguists had no privileged way of distinguishing the possible formal patterns of a language from the merely probable. Many of the kinds of sentences reported by theorists to be ungrammatical are actually used quite grammatically in rare contexts, Authentic examples can be found in very large collections of language use, such as the World Wide Web ,
A Voyage into Uncertainty, Thinking Reed: Centennial Essays by Graduates of Reed College, p.74, 2011. ,
Data in linguistics, The Linguistic Review, vol.21, issue.3-4, pp.3-4, 2004. ,
DOI : 10.1515/tlir.2004.21.3-4.175
Methods and Tactics in the Construction of a Lexicon-Grammar, Linguistics in the Morning Calm 2: Selected Papers from SICOL 1986, pp.177-197, 1988. ,
Using Lexical-Grammar Tables for French Verbs in a Large-Coverage Parser, Human Language Technology. Challenges for Computer Science and Linguistics: Lecture Notes in Computer Science, vol.6, pp.562-183, 2011. ,
A Generic Tool to Generate a Lexicon for NLP from Lexicon-Grammar Tables, " in Actes du " 27e Colloque international sur le lexique et la grammaire " (L'Aquila, 10-13 septembre 2008) Seconde partie, pp.79-93, 2010. ,
Variation and reproducibility in linguistics, Linguistic Universals and Language Variation, p.251, 2011. ,
DOI : 10.1515/9783110238068.237
Variation and reproducibility in linguistics, Linguistic Universals and Language Variation, p.254, 2011. ,
Semantics and Syntactic Regularity, 1973. ,
Psych-verbs and ?-theory, Natural Language and Linguistic Theory, vol.16, issue.3, pp.291-352, 1988. ,
DOI : 10.1007/BF00133902
Magnitude Estimation of Use our professional PDF creation service at http://www.htm2pdf.co.uk! Linguistic Acceptability, pp.32-68, 1996. ,
Syntactic Structures (The Hague, p.15, 1957. ,
Syntactic Structures (The Hague, pp.35-36, 1957. ,
The Empirical Base of Linguistics: Grammaticality Judgments and Linguistic Methodology Schütze provides a detailed discussion of how inconsistently Chomsky has used the terms grammaticality and acceptability. &larrhk, 1996. ,
Speaker-oriented adverbs, Natural Language & Linguistic Theory, vol.60, issue.5, pp.497-544, 2009. ,
DOI : 10.1007/s11049-009-9069-1
When we compare meanings as we did between La décoratrice enjolive la vitrine de minijupes claires (The decorator ornaments the shop window with bright miniskirts), and La décoratrice enjolive la vitrine de sa minijupe claire (The decorator ornaments the shop window with her bright miniskirt), or between the two interpretations of Pierre amuse Paul (Peter entertains Paul; Paul finds Peter funny), we will say we proceed to differential assessment of meaning. The distinction has a parallel in measurement of physical quantities. For instance, the absolute measurement of a temperature or weight is relatively coarse, whereas differential measurement of the same variables is quite sharp ,
Méthodes en syntaxe: régime des constructions complétives (Syntax Methods: The System of Complements Constructions), p.32, 1975. ,
On the Failure of Generative Grammar, Language, vol.55, issue.4, p.868, 1979. ,
DOI : 10.2307/412748
What was Transformational Grammar? A Review of: Noam Chomsky, The Logical Structure of Linguistic Theory, Lingua, vol.48, p.370, 1979. ,
Méthodes en syntaxe: régime des constructions complétives (Syntax Methods: The System of Complements Constructions), 1975. ,
Bees are Swarming in the Garden: A Systematic Synchronic Study of Productivity, pp.288-346, 1983. ,
Verbs with a sentential subject: A lexical examination of a sub-set of psych verbs, Lingvisticae Investigationes International Journal of Linguistics and Language Resources, vol.25, issue.1, pp.97-147, 2002. ,
DOI : 10.1075/li.25.1.08sal
Some Observations on the Foundation of Linguistics, 1987. ,
Methodological and interdisciplinary stance in Corpus Linguistics, Perspectives on Corpus Linguistics, p.87, 2011. ,
DOI : 10.1075/scl.48.06gri
Data-Intensive Experimental Linguistics, Linguistic Issues in Language Technology, vol.6, issue.2, p.9, 2011. ,
In morphology and lexicography, a lemma (plural lemmas or lemmata) is the Use our professional PDF creation service at http://www.htm2pdf.co.uk! canonical form, dictionary form, or citation form of a set of words (headword) In English, for example, run, runs, ran and running are forms of the same lexeme, with run as the lemma. Lexeme, in this context, refers to the set of all the forms that have the same meaning, and lemma refers to the particular form that is chosen by convention to represent the lexeme. In lexicography, this unit is usually also the citation form or headword by which it is indexed. ? Lemmas or word stems are used often in corpus linguistics for determining word frequency, such usage the specific definition of " lemma " is flexible depending on the task it is being used for. &larrhk ,
The English Lexicon Project Their dictionary does provide parts of speech of the words, and they do not report the source of the information, but they do not claim that this source is free of subjectivity They probably trusted grammarians or lexicographers. &larrhk, Behavior Research Methods, vol.39, issue.3, pp.445-59, 2007. ,
confrontation with linguistic reality reveals the existence of Use our professional PDF creation service at http://www.htm2pdf.co.uk! unexpected cases of low consistency. However, his methodological contribution to confronting such aspects of language does not go beyond recommending a psychological attitude: [Y]ou accept and incorporate into your working method, your theory, the assumption that language is not especially uniform, and you make the ragged, messy nature of your data and their unpredictable margins visible and public ? we should be prepared to question [consistency] when the competing demands of accuracy and integrity militate against it ,
The Ideal of Consistency in Thinking about Language, Southwest Journal of Linguistics, vol.19, issue.1, p.2, 2000. ,
Maurice Gross indexed 26,000 verbal idioms and 12,000 adverbial idioms Éric Laporte, Memoriam Maurice Gross. " (Paper presented at the Language and Technology Conference (LTC), p.3, 2005. ,
Defining a verb taxonomy by a decision tree, Autour des verbes: Constructions et interprétations (Around Verbs: Constructions and Interpretations) ,
DOI : 10.1075/lis.29.07lap
URL : https://hal.archives-ouvertes.fr/hal-00860386
Language: An Introduction to the Study of Speech, p.38, 1921. ,
DOI : 10.1017/CBO9781139629430
Grammaire des noms de maladie (The Grammar of Disease Names), Langue Française, vol.69, p.109, 1986. ,
REMARKS ON NOMINALIZATION, p.185, 1970. ,
DOI : 10.1515/9783110814231.11
The Ascent of Science, p.16, 1998. ,
Foot and Word in Prosodic Morphology: the Arabic Use our professional PDF creation service at http://www.htm2pdf.co.uk! Broken Plural, Natural Language and Linguistic Theory, vol.8, issue.2, p.267, 1990. ,
"Corpus linguistics" or "Computer-aided armchair linguistics", Directions in Corpus Linguistics: Proceedings of Nobel Symposium, pp.4-8 ,
DOI : 10.1515/9783110867275.35
