Adaptive Motion Pooling and Diffusion for Optical Flow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
We study the impact of local context of an image (contrast and 2D structure) on spatial motion integration by MT neurons. To do so, we revisited the seminal work by Heeger and Simoncelli (HS) using spatio-temporal filters to estimate optical flow from V1-MT feedforward interactions. However, the HS model cannot deal with several problems encountered in real scenes (e.g., blank wall problem and motion discontinuities). Here, we propose to extend the HS model with adaptive processing by focussing on the role of local context indicative of the local velocity estimates reliability. We set a network structure representative of V1, V2 and MT. We incorporate three functional principles observed in primate visual system: contrast adaptation, adaptive afferent pooling and MT diffusion that are adaptive dependent upon the 2D image structure (Adaptive Motion Pooling and Diffusion, AMPD).We evaluated both HS and AMPD models performance on Middlebury optical flow estimation dataset. Our results show that the AMPD model performs better than the HS model and its overall performance is comparable with many modern computer vision. The AMPD model has to be further improved by integrating feedback from MT to V1 to better recover true velocities around motion discontinuities. However, we think that this adaptive model can serve as a ground for future research in biologically-inspired computer vision.
RR-8695.pdf (4.1 Mo) Télécharger le fichier
hal-01131099 , version 1 (12-03-2015)
hal-01131099 , version 2 (14-10-2015)
  • HAL Id : hal-01131099 , version 1
N. V. Kartheek Medathati, Manuela Chessa, Guillaume S. Masson, Pierre Kornprobst, Fabio Solari. Adaptive Motion Pooling and Diffusion for Optical Flow. [Research Report] RR-8695, INRIA Sophia-Antipolis; University of Genoa; INT la Timone; INRIA. 2015. ⟨hal-01131099v1⟩
496 Consultations
340 Téléchargements
