New interface
Reports (Research report)
Adaptive Motion Pooling and Diffusion for Optical Flow
Abstract : We study the impact of local context of an image (contrast and 2D structure) on spatial motion integration by MT neurons. To do so, we revisited the seminal work by Heeger and Simoncelli (HS) using spatio-temporal filters to estimate optical flow from V1-MT feedforward interactions. However, the HS model cannot deal with several problems encountered in real scenes (e.g., blank wall problem and motion discontinuities). Here, we propose to extend the HS model with adaptive processing by focussing on the role of local context indicative of the local velocity estimates reliability. We set a network structure representative of V1, V2 and MT. We incorporate three functional principles observed in primate visual system: contrast adaptation, adaptive afferent pooling and MT diffusion that are adaptive dependent upon the 2D image structure (Adaptive Motion Pooling and Diffusion, AMPD).We evaluated both HS and AMPD models performance on Middlebury optical flow estimation dataset. Our results show that the AMPD model performs better than the HS model and its overall performance is comparable with many modern computer vision. The AMPD model has to be further improved by integrating feedback from MT to V1 to better recover true velocities around motion discontinuities. However, we think that this adaptive model can serve as a ground for future research in biologically-inspired computer vision.
Complete list of metadata
Cited literature [44 references]  Display  Hide  Download
https://hal.inria.fr/hal-01131099
Contributor : Pierre Kornprobst Connect in order to contact the contributor
Submitted on : Wednesday, October 14, 2015 - 2:11:48 PM
Last modification on : Friday, November 25, 2022 - 6:50:05 PM
Long-term archiving on: : Monday, April 17, 2017 - 10:54:17 PM
File
RR-8695.pdf
Identifiers
  • HAL Id : hal-01131099, version 2
Citation
N. V. Kartheek Medathati, Manuela Chessa, Guillaume S. Masson, Pierre Kornprobst, Fabio Solari. Adaptive Motion Pooling and Diffusion for Optical Flow. [Research Report] RR-8695, INRIA Sophia-Antipolis; University of Genoa; INT la Timone. 2015, pp.19. ⟨hal-01131099v2⟩
Share
Metrics
Record views
487
Files downloads
327
