Labelled OBS test bed for contention resolution study, 2008 5th International Conference on Broadband Communications, Networks and Systems, pp.8-11, 2008. ,
DOI : 10.1109/BROADNETS.2008.4769048
URL : https://hal.archives-ouvertes.fr/hal-01184144
Demonstration of the interconnection of two optical packet rings with a hybrid optoelectronic packet router, 36th European Conference and Exhibition on Optical Communication, 2010. ,
DOI : 10.1109/ECOC.2010.5621414
Demonstration of optical label detection and 10???Gbit???s packet routing using 4??4 optical crosspoint switch, Electronics Letters, vol.41, issue.8, pp.491-492, 2005. ,
DOI : 10.1049/el:20057295
Traveling wave semiconductor laser amplifier detectors, Journal of Lightwave Technology, vol.8, issue.4, pp.610-617, 1990. ,
DOI : 10.1109/50.50767
Semiconductor optical amplifier used as an in-line detector with the signal DC-component conservation, Journal of Lightwave Technology, vol.16, issue.7 ,
DOI : 10.1109/50.701408
Up to 16 dB improvement in detected voltage using two-section semiconductor optical amplifier detector, Electronics Letters, vol.28, issue.5, pp.474-476, 1992. ,
DOI : 10.1049/el:19920299
