New interface
Conference papers
Learning Inverse Dynamics Models with Contacts
Abstract : — In whole-body control, joint torques and external forces need to be estimated accurately. In principle, this can be done through pervasive joint-torque sensing and accurate system identification. However, these sensors are expensive and may not be integrated in all links. Moreover, the exact position of the contact must be known for a precise estimation. If contacts occur on the whole body, tactile sensors can estimate the contact location, but this requires a kinematic spatial calibration, which is prone to errors. Accumulating errors may have dramatic effects on the system identification. As an alternative to classical model-based approaches we propose a data-driven mixture-of-experts learning approach using Gaus-sian processes. This model predicts joint torques directly from raw data of tactile and force/torque sensors. We compare our approach to an analytic model-based approach on real world data recorded from the humanoid iCub. We show that the learned model accurately predicts the joint torques resulting from contact forces, is robust to changes in the environment and outperforms existing dynamic models that use of force/ torque sensor data.
Document type :
Conference papers
Complete list of metadata
Cited literature [25 references]  Display  Hide  Download
https://hal.inria.fr/hal-01131611
Contributor : Serena Ivaldi Connect in order to contact the contributor
Submitted on : Saturday, March 14, 2015 - 1:41:25 PM
Last modification on : Wednesday, September 7, 2022 - 3:36:04 PM
Long-term archiving on: : Monday, June 15, 2015 - 10:10:55 AM
File
ICRA15_1495_FI.pdf
Identifiers
  • HAL Id : hal-01131611, version 1
Citation
Roberto Calandra, Serena Ivaldi, Marc Peter Deisenroth, Elmar Rueckert, Jan Peters. Learning Inverse Dynamics Models with Contacts. Proc. IEEE Int. Conf. on Robotics and Automation (ICRA), May 2015, Seattle, WA, United States. ⟨hal-01131611⟩
Share
Metrics
Record views
506
Files downloads
631
