Bio-Inspired Computer Vision: Setting the Basis for a New Departure
Studies in biological vision have always been a great source of inspiration for
design of computer vision algorithms. In the past, several successful methods were designed with
varying degrees of correspondence with biological vision studies, ranging from purely functional
inspiration to methods that utilize models that were primarily developed for explaining biological
observations. Even though it seems well recognized that computational models of visual cortex
can help in design of computer vision algorithms, it is a non-trivial exercise for a computer vision
researcher to mine relevant information from biological literature as very few studies in biology are
organized at a task level. This has lead to a widening gap between biological vision and computer
vision research. In this paper we aim to bridge this gap by provide insights and methodology to
envision a new departure in this area. Not only we revisit some of the main features of biological
vision and discuss the foundations of existing computational studies modeling biological vision, but
also we revisit three classical computer vision tasks from a biological perspective: image sensing,
segmentation and optical flow. Using this task-centric approach, we discuss well-known biological
functional principles and compare them with approaches taken by computer vision. Based on this
comparative analysis of computer and biological vision, we will present some recent promising
approaches in modelling biological vision and we highlight a few novel ideas that we think are
promising for future investigations in computer vision. To this extent, this papers provides new
insights for the design of biology-based computer vision algorithms and pave a way for much needed
interaction between the two communities.
