Identification of Cl(Ca) channel distributions in olfactory cilia, Mathematical Methods in the Applied Sciences, vol.72, issue.15, pp.31-1860, 2008. ,
DOI : 10.1002/mma.1007
Estimating the division rate of the growthfragmentation equation with a self-similar kernel, Inverse Problems, p.30, 2014. ,
Determination of the Calcium channel distribution in the olfactory system, Journal of Inverse and Ill-Posed Problems, 2013. ,
DOI : 10.1515/jip-2013-0033
URL : https://hal.archives-ouvertes.fr/hal-01112038
Regularization of inverse problems, Mathematics and its Applications, 1996. ,
Clustering of Cyclic-Nucleotide-Gated Channels in Olfactory Cilia, Biophysical Journal, vol.91, issue.1, pp.91-179, 2006. ,
DOI : 10.1529/biophysj.105.079046
Perturbation approximation of solutions of a nonlinear inverse problem arising in olfaction experimentation, Journal of Mathematical Biology, vol.81, issue.5-6, pp.745-765, 2007. ,
DOI : 10.1007/s00285-007-0104-8
Numerical approximation of solutions to nonlinear inverse problems arising in olfaction experimentation, PAMM, vol.91, issue.1, pp.43-945, 2006. ,
DOI : 10.1002/pamm.200700657
Integral equation models for the inverse problem of biological ion channel distributions, Journal of Physics: Conference Series, vol.73, p.73, 2007. ,
DOI : 10.1088/1742-6596/73/1/012006
Origin of the chloride current in olfactory transduction, Neuron, vol.11, issue.1, pp.11-123, 1993. ,
DOI : 10.1016/0896-6273(93)90276-W
Calcium-activated chloride conductance in frog olfactory cilia, J. Neurosci, vol.11, pp.3624-3629, 1991. ,
Transmembrane currents in frog olfactory cilia, The Journal of Membrane Biology, vol.73, issue.Suppl. 36, pp.75-81, 1991. ,
DOI : 10.1007/BF01868593
An electrophysiological survey of frog olfactory cilia, J. Exp. Biol, vol.195, pp.307-328, 1994. ,
Fourier Analysis on Groups, 1962. ,
