Validation of a simple fouling model for submerged membrane bioreactor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Most of the published membrane bioreactor (MBR) models have been proposed for process description and cognition, resulting in a large number of parameters to estimate from experimental data. These models are usually too complex for process control, and there is a need for simple, dedicated, dynamic models. In this study, attention is focused on the fouling phenomenon, which hampers the efficient operation of MBRs, and a simple model is proposed and validated using a large data base collected from a pilot plant. This model includes several manipulated variables, e.g., the effluent flow rate and the air crossflow, as well as a measurable perturbation such as the ambient temperature. To ease the identification procedure, a separation of the time scales of the process in slow and fast dynamics is exploited. The results show that the model can be used to predict the trans-membrane pressure behavior in a medium-term, about 10 days ahead.
Fichier non déposé
hal-02739920 , version 1 (02-06-2020)
Guilherme Araujo Pimentel, Montse Dalmau, Alejandro Vargas, Joaquim Comas, Ignasi Rodriguez-Roda, et al.. Validation of a simple fouling model for submerged membrane bioreactor. 8. Vienna International Conference on Mathematical Modelling : MathMod 2015, Vienna University of Technology (TU Wien). Vienne, AUT., Feb 2015, Vienna, Austria. pp.737-742, ⟨10.1016/j.ifacol.2015.05⟩. ⟨hal-02739920⟩
279 Consultations
0 Téléchargements
