Structure preserving reductions among convex optimization problems, Journal of Computer and System Sciences, vol.21, issue.1, pp.136-153, 1980. ,
DOI : 10.1016/0022-0000(80)90046-X
URL : http://doi.org/10.1016/0022-0000(80)90046-x
Survivable Networks: Algorithms for Diverse Routing, 1998. ,
Set Partitioning via Inclusion-Exclusion, SIAM Journal on Computing, vol.39, issue.2, pp.546-563, 2009. ,
DOI : 10.1137/070683933
Paths and cycles in colored graphs, Australas. J. Combin, vol.31, pp.299-311, 2005. ,
On the red-blue set cover problem, Proceedings of the Eleventh Annual ACM-SIAM Symposium on Discrete Algorithms, SODA '00, pp.345-353, 2000. ,
New results on the computability and complexity of points?to analysis, ACM SIGPLAN-SIGACT symposium on principles of programming languages (POPL), pp.115-125, 2003. ,
SHARED RISK RESOURCE GROUP COMPLEXITY AND APPROXIMABILITY ISSUES, Parallel Processing Letters, vol.17, issue.02, pp.169-184, 2007. ,
DOI : 10.1142/S0129626407002958
URL : https://hal.archives-ouvertes.fr/hal-00371100
Combinatorial optimization in networks with Shared Risk Link Groups, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01053859
Graph transformation approaches for diverse routing in shared risk resource group (SRRG) failures, Computer Networks, vol.52, issue.12, pp.2381-2394, 2008. ,
DOI : 10.1016/j.comnet.2008.04.017
Shared-Risk Logical Span Groups in Span-Restorable Optical Networks: Analysis and Capacity Planning Model, Photonic Network Communications, vol.18, issue.10, pp.35-53, 2005. ,
DOI : 10.1007/s11107-005-4530-5
Fixed-parameter tractability and completeness II: On completeness for W[1], Theoretical Computer Science, vol.141, issue.1-2, pp.109-131, 1995. ,
DOI : 10.1016/0304-3975(94)00097-3
Fundamentals of Parameterized Complexity. Texts in Computer Science, 2013. ,
A graph theoretic model for complex network failure scenarios, 8th INFORMS Telecommunications Conference, 2006. ,
The parameterized complexity of some minimum label problems, Journal of Computer and System Sciences, vol.76, issue.8, pp.727-740, 2010. ,
DOI : 10.1016/j.jcss.2010.02.012
A simple algorithm for finding maximal network flows and an application to the Hitchcock problem, Journal canadien de math??matiques, vol.9, issue.0, pp.210-218, 1957. ,
DOI : 10.4153/CJM-1957-024-0
Computers and Intractability: A Guide to the theory of NPcompleteness, Freeman NY, 1979. ,
A Novel Survivable Routing Algorithm With Partial Shared-Risk Link Groups (SRLG)-Disjoint Protection Based on Differentiated Reliability Constraints in WDM Optical Mesh Networks, Journal of Lightwave Technology, vol.25, issue.6, pp.1410-1415, 2007. ,
DOI : 10.1109/JLT.2007.896772
Approximation algorithms and hardness results for??labeled connectivity problems, Journal of Combinatorial Optimization, vol.33, issue.1, pp.437-453, 2007. ,
DOI : 10.1007/s10878-007-9044-x
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.118.6675
Algorithm 447: efficient algorithms for graph manipulation, Communications of the ACM, vol.16, issue.6, pp.372-378, 1973. ,
DOI : 10.1145/362248.362272
Clique is hard to approximate within n/sup 1-??/, Proceedings of 37th Conference on Foundations of Computer Science, pp.105-142, 1999. ,
DOI : 10.1109/SFCS.1996.548522
Diverse routing in mesh optical networks, IEEE Transactions on Communications, vol.51, pp.489-494, 2003. ,
Improving Robustness of PGP Keyrings by Conflict Detection, RSA Conference Cryptographers' Track (CT-RSA), pp.194-207, 2004. ,
DOI : 10.1007/978-3-540-24660-2_16
Maximum bounded 3-dimensional matching is MAX SNP-complete, Information Processing Letters, vol.37, issue.1, pp.27-35, 1991. ,
DOI : 10.1016/0020-0190(91)90246-E
Diverse routing in WDM optical networks with shared risk link group (SRLG) failures, Proc. DRCN, pp.445-452, 2005. ,
Invitation to fixed-parameter algorithms. Oxford lecture series in mathematics and its applications, 2006. ,
Shared-risk link group (SRLG)-diverse path provisioning under hybrid service level agreements in wavelength-routed optical mesh networks: formulation and solution approaches, OptiComm 2003: Optical Networking and Communications, pp.918-931, 2005. ,
DOI : 10.1117/12.533306
Disjoint paths in a network, Networks, vol.19, issue.2, pp.125-145, 1974. ,
DOI : 10.1002/net.3230040204
A quick method for finding shortest pairs of disjoint paths, Networks, vol.3, issue.2, pp.325-336, 1984. ,
DOI : 10.1002/net.3230140209
Finding paths in graphs avoiding forbidden transitions, Discrete Applied Mathematics, vol.126, issue.2-3, pp.261-273, 2003. ,
DOI : 10.1016/S0166-218X(02)00251-2
IMSH: an iterative heuristic for SRLG diverse routing in WDM mesh networks, Proceedings. 13th International Conference on Computer Communications and Networks (IEEE Cat. No.04EX969), pp.199-204, 2004. ,
DOI : 10.1109/ICCCN.2004.1401627
Survivable virtual topology routing under shared risk link groups in WDM networks, First International Conference on Broadband Networks, pp.130-139, 2004. ,
DOI : 10.1109/BROADNETS.2004.81
Minimum-color path problems for reliability in mesh networks, Proc. IEEE INFOCOM, pp.2658-2669, 2005. ,
Evolutionary Algorithms Refining a Heuristic: A Hybrid Method for Shared-Path Protections in WDM Networks Under SRLG Constraints, IEEE Transactions on Systems, Man and Cybernetics, Part B (Cybernetics), vol.37, issue.1, pp.51-61, 2007. ,
DOI : 10.1109/TSMCB.2006.883269
