A robust and scalable implementation of the Parks-McClellan algorithm for designing FIR filters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Mathematical Software Année : 2016
Silviu-Ioan Filip
With a long history dating back to the beginning of the 1970s, the Parks-McClellan algorithm is probably the most well-known approach for designing finite impulse response filters. Despite being a standard routine in many signal processing packages, it is possible to find practical design specifications where existing codes fail to work. Our goal is twofold. We first examine and present solutions for the practical difficulties related to weighted minimax polynomial approximation problems on multi-interval domains (i.e., the general setting under which the Parks-McClellan algorithm operates). Using these ideas, we then describe a robust implementation of this algorithm. It routinely outperforms existing minimax filter design routines.
pm.pdf (714.3 Ko) Télécharger le fichier
hal-01136005 , version 1 (26-03-2015)
hal-01136005 , version 2 (22-04-2015)
hal-01136005 , version 3 (15-01-2016)
hal-01136005 , version 4 (27-04-2016)
hal-01136005 , version 5 (04-05-2016)
  • HAL Id : hal-01136005 , version 5
Silviu-Ioan Filip. A robust and scalable implementation of the Parks-McClellan algorithm for designing FIR filters. ACM Transactions on Mathematical Software, 2016, 43 (1), pp.7:1 - 7:24. ⟨hal-01136005v5⟩
719 Consultations
5335 Téléchargements
