A review of wireless sensors and networks' applications in agriculture, Computer Standards & Interfaces, vol.36, issue.2, pp.263-270, 2014. ,
On implementing omega with weak reliability and synchrony assumptions, Proceedings of the Twenty-second Annual Symposium on Principles of Distributed Computing, pp.306-314, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-00154822
Communication-efficient leader election and consensus with limited link synchrony, Proceedings of the twenty-third annual ACM symposium on Principles of distributed computing, pp.328-337, 2004. ,
Eventual Leader Election in Evolving Mobile Networks, Principles of Distributed Systems -17th International Conference, OPODIS 2013 Proceedings, pp.23-37, 2013. ,
DOI : 10.1007/978-3-319-03850-6_3
URL : https://hal.archives-ouvertes.fr/hal-00927651
Failure detectors in homonymous distributed systems (with an application to consensus), Distributed Computing Systems (ICDCS), 2012 IEEE 32nd International Conference on, pp.275-284, 2012. ,
DOI : 10.1016/j.jpdc.2015.05.007
Performance analysis of a hierarchical failure detector, 2003 International Conference on Dependable Systems and Networks, 2003. Proceedings., pp.635-644, 2003. ,
DOI : 10.1109/DSN.2003.1209973
On the road to the weakest failure detector for <mml:math altimg="si1.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi>k</mml:mi></mml:math>-set agreement in message-passing systems, Theoretical Computer Science, vol.412, issue.33, pp.4273-4284, 2011. ,
DOI : 10.1016/j.tcs.2010.11.007
Anonymous asynchronous systems: the case of failure detectors, Distributed Computing, vol.7, issue.1, pp.141-158, 2013. ,
DOI : 10.1007/s00446-012-0169-5
URL : https://hal.archives-ouvertes.fr/inria-00452799
Smart Redundancy for Distributed Computation, 2011 31st International Conference on Distributed Computing Systems, pp.665-676, 2011. ,
DOI : 10.1109/ICDCS.2011.25
The weakest failure detector for solving consensus, Journal of the ACM, vol.43, issue.4, pp.685-722, 1996. ,
DOI : 10.1145/234533.234549
Unreliable failure detectors for reliable distributed systems, Journal of the ACM (JACM), vol.43, issue.2, pp.225-267, 1996. ,
On the quality of service of failure detectors . Computers, IEEE Transactions on, vol.51, issue.5, pp.561-580, 2002. ,
Reducing ?? to ???, Information Processing Letters, vol.67, issue.6, pp.289-293, 1998. ,
DOI : 10.1016/S0020-0190(98)00122-7
Improving the quality of service of failure detectors with snmp and artificial neural networks, Anais do 22o. Simpósio Brasileiro de Redes de Computadores, pp.583-586, 2004. ,
Qos self-configuring failure detectors for distributed systems, IFIP International Conference on Distributed Applications and Interoperable Systems, pp.126-140, 2010. ,
Shared memory vs message passing, 2003. ,
The weakest failure detectors to solve certain fundamental problems in distributed computing, Proceedings of the twenty-third annual ACM symposium on Principles of distributed computing , PODC '04, pp.338-346, 2004. ,
DOI : 10.1145/1011767.1011818
Mutual exclusion in asynchronous systems with failure detectors, Journal of Parallel and Distributed Computing, vol.65, issue.4, pp.492-505, 2005. ,
DOI : 10.1016/j.jpdc.2004.11.008
URL : https://hal.archives-ouvertes.fr/hal-00130799
Impossibility of distributed consensus with one faulty process, Journal of the ACM (JACM), vol.32, issue.2, pp.374-382, 1985. ,
Fault tolerance in wireless sensor network using hand-off and dynamic power adjustment approach, Journal of Network and Computer Applications, vol.36, issue.4, pp.1174-1185, 2013. ,
DOI : 10.1016/j.jnca.2013.02.005
Fault-Tolerant Leader Election in Mobile Dynamic Distributed Systems, 2013 IEEE 19th Pacific Rim International Symposium on Dependable Computing, pp.78-87, 2013. ,
DOI : 10.1109/PRDC.2013.17
Two-ways adaptive failure detection with the ?-failure detector, Workshop on Adaptive Distributed Systems (WADiS03), pp.22-27, 2003. ,
The ? accrual failure detector, Reliable Distributed Systems Proceedings of the 23rd IEEE International Symposium on, pp.66-78, 2004. ,
A Proposal of Forwarding Method for Urgent Messages on an Ubiquitous Wireless Sensor Network, 6th Asia-Pacific Symposium on Information and Telecommunication Technologies, pp.293-298, 2005. ,
DOI : 10.1109/APSITT.2005.203673
Congestion avoidance and control, In ACM SIGCOMM Computer Communication Review, pp.314-329, 1988. ,
Implementing unreliable failure detectors with unknown membership, Information Processing Letters, vol.100, issue.2, pp.60-63, 2006. ,
DOI : 10.1016/j.ipl.2006.05.009
Threshold protocols in survivor set systems, Distributed Computing, vol.22, issue.4, pp.135-149, 2010. ,
DOI : 10.1007/s00446-010-0107-3
Implementing the weakest failure detector for solving the consensus problem, International Journal of Parallel, Emergent and Distributed Systems, vol.28, issue.6, pp.537-555, 2013. ,
DOI : 10.1007/s004460050032
On the implementation of unreliable failure detectors in partially synchronous systems, IEEE Transactions on Computers, vol.53, issue.7, pp.815-828, 2004. ,
DOI : 10.1109/TC.2004.33
Improving availability in distributed systems with failure informers, Proc. of NSDI, pp.427-441, 2013. ,
Asynchronous implementation of failure detectors, 2003 International Conference on Dependable Systems and Networks, 2003. Proceedings., pp.22-25, 2003. ,
DOI : 10.1109/DSN.2003.1209946
From to : A simple bounded quiescent reliable broadcast-based transformation, Journal of Parallel and Distributed Computing, vol.67, issue.1, pp.125-129, 2007. ,
DOI : 10.1016/j.jpdc.2006.06.002
A failure detector that gives information on the degree of confidence in the system, 2015 IEEE Symposium on Computers and Communication, pp.532-537, 2015. ,
A new adaptive accrual failure detector for dependable distributed systems, Proceedings of the 2007 ACM symposium on Applied computing , SAC '07, pp.551-555, 2007. ,
DOI : 10.1145/1244002.1244129
RepFD - Using Reputation Systems to Detect Failures in Large Dynamic Networks, 2015 44th International Conference on Parallel Processing, pp.91-100, 2015. ,
DOI : 10.1109/ICPP.2015.18
