Theoretical and Numerical Study of the Problem of Abort Landing in the Presence of Windshear - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
We analyze both theoretically and numerically the problem of abort landing in the presence of windshear. A pertinent model of optimal control is constructed in order to allow numerical simulations through an open source software. We verify that the numerical results correspond to the mathematical theory and in particular we analyze as much as possible the junction conditions in presence of state constraints. The code written to analyze the problem will be available as a contribution in bocop.org.
Mots clés
rapportEN.pdf (265.12 Ko) Télécharger le fichier
hal-01136701 , version 1 (27-03-2015)
  • HAL Id : hal-01136701 , version 1
Ivan Cadena Guaqueta. Theoretical and Numerical Study of the Problem of Abort Landing in the Presence of Windshear. [Research Report] INRIA Saclay - Equipe Commands; Ecole Centrale Paris - Laboratoire MAS. 2015. ⟨hal-01136701⟩
247 Consultations
133 Téléchargements
