Deliberation for autonomous robots: A survey - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Artificial Intelligence Année : 2017
Félix Ingrand
Malik Ghallab
Autonomous robots facing a diversity of open environments and performing a variety of tasks and interactions need explicit deliberation in order to fulfill their missions. Deliberation is meant to endow a robotic system with extended, more adaptable and robust functionalities, as well as reduce its deployment cost. The ambition of this survey is to present a global overview of deliberation functions in robotics and to discuss the state of the art in this area. The following five deliberation functions are identified and analyzed: planning, acting, monitoring, observing, and learning. The paper introduces a global perspective on these deliberation functions and discusses their main characteristics, design choices and constraints. The reviewed contributions are discussed with respect to this perspective. The survey focuses as much as possible on papers with a clear robotics content and with a concern on integrating several deliberation functions.
paper-final.pdf (1.64 Mo) Télécharger le fichier
hal-01137921 , version 1 (31-03-2015)
Félix Ingrand, Malik Ghallab. Deliberation for autonomous robots: A survey. Artificial Intelligence, 2017, 247 pp.10-44. ⟨10.1016/j.artint.2014.11.003⟩. ⟨hal-01137921⟩
906 Consultations
2737 Téléchargements
