New interface
Journal articles
Existence of global strong solutions to a beam-fluid interaction system
Céline Grandmont 1 Matthieu Hillairet 2
1 REO - Numerical simulation of biological flows
LJLL - Laboratoire Jacques-Louis Lions, UPMC - Université Pierre et Marie Curie - Paris 6, Inria de Paris
Abstract : We study an unsteady non linear fluid-structure interaction problem which is a simplified model to describe blood flow through viscoleastic arteries. We consider a Newtonian incompressible two-dimensional flow described by the Navier-Stokes equations set in an unknown domain depending on the displacement of a structure, which itself satisfies a linear viscoelastic beam equation. The fluid and the structure are fully coupled via interface conditions prescribing the continuity of the velocities at the fluid-structure interface and the action-reaction principle. We prove that strong solutions to this problem are global-in-time. We obtain in particular that contact between the viscoleastic wall and the bottom of the fluid cavity does not occur in finite time. To our knowledge, this is the first occurrence of a no-contact result, but also of existence of strong solutions globally in time, in the frame of interactions between a viscous fluid and a deformable structure.
Complete list of metadata
https://hal.inria.fr/hal-01138736
Contributor : Celine Grandmont Connect in order to contact the contributor
Submitted on : Thursday, April 2, 2015 - 3:20:46 PM
Last modification on : Friday, August 5, 2022 - 10:51:42 AM
Long-term archiving on: : Friday, July 3, 2015 - 10:36:52 AM
Contact_FB_submitted.pdf
Identifiers
Citation
Céline Grandmont, Matthieu Hillairet. Existence of global strong solutions to a beam-fluid interaction system. Archive for Rational Mechanics and Analysis, 2016, 3, pp.1283-1333. ⟨10.1007/s00205-015-0954-y⟩. ⟨hal-01138736⟩
Share
Metrics
Record views
481
Files downloads
302
