Geographic Routing Protocol for Peer-to-Peer Smart Grid Neighborhood Area Network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The distribution segment of the power system is of great importance in the smart grid (SG). The deployment of ICT to support conventional grid will solve legacy problems that used to prevent implementation of smart services such as smart metering, demand side management or the integration of Distributed Energy Resources (DERs) within the smart grid. In this contribution, GRACO, a new geographic routing algorithm is proposed to support exploitation of SG full potential. We demonstrate, through simulations,the effectiveness of GRACO in terms of scalability, peer-to-peer routing, end-to-end delay and delivery rate.
EEEIC2015-478.pdf (1.23 Mo) Télécharger le fichier
hal-01139120 , version 1 (16-07-2015)
hal-01139120 , version 2 (18-07-2015)
  • HAL Id : hal-01139120 , version 2
Mouna Rekik, Zied Chtourou, Nathalie Mitton. Geographic Routing Protocol for Peer-to-Peer Smart Grid Neighborhood Area Network . The 15 IEEE International Conference on Environment and Electrical Engineering, Jun 2015, Rome, Italy. ⟨hal-01139120v2⟩
Collections
INRIA INRIA2
480 Consultations
536 Téléchargements
