New interface
Reports (Technical report)
ROPocop - Dynamic Mitigation of Code-Reuse Attacks
Andreas Follner 1, * Eric Bodden 1
* Corresponding author
Abstract : Control-flow attacks, usually achieved by exploiting a buffer-overflow vulnerability, have been a serious threat to system security for over fifteen years. Researchers have answered the threat with various mitigation techniques, but nevertheless, new exploits that successfully bypass these technologies still appear on a regular basis. In this paper, we propose ROPocop, a novel approach for detecting and preventing the execution of injected code and for mitigating code-reuse attacks such as return-oriented programming (RoP). ROPocop uses dynamic binary instrumentation, requiring neither access to source code nor debug symbols or changes to the operating system. It mitigates attacks by both monitoring the program counter at potentially dangerous points and by detecting suspicious program flows. We have implemented ROPocop for Windows x86 using PIN, a dynamic program instrumentation framework from Intel. Benchmarks using the SPEC CPU2006 suite show an average overhead of 2.4x, which is comparable to similar approaches, which give weaker guarantees. Real-world applications show only an initially noticeable input lag and no stutter. In our evaluation our tool successfully detected all 11 of the latest real-world code-reuse exploits, with no false alarms. Therefore, despite the overhead, it is a viable, temporary solution to secure critical systems against exploits if a vendor patch is not yet available.
Document type :
Complete list of metadata
Cited literature [27 references]  Display  Hide  Download
https://hal.inria.fr/hal-01140685
Contributor : Follner Andreas Connect in order to contact the contributor
Submitted on : Thursday, April 9, 2015 - 11:30:40 AM
Last modification on : Wednesday, October 26, 2022 - 8:13:57 AM
Long-term archiving on: : Friday, July 10, 2015 - 10:21:36 AM
paper.pdf
Identifiers
  • HAL Id : hal-01140685, version 1
  • ARXIV : 1504.02288
Collections
Citation
Andreas Follner, Eric Bodden. ROPocop - Dynamic Mitigation of Code-Reuse Attacks. [Technical Report] EC SPRIDE; TU Darmstadt. 2015. ⟨hal-01140685⟩
Share
Metrics
Record views
26
Files downloads
95
