Other publications
FECFRAMEv2: Adding Sliding Encoding Window Capabilities to the FEC Framework: Problem Position
Vincent Roca 1
1 PRIVATICS - Privacy Models, Architectures and Tools for the Information Society
Inria Grenoble - Rhône-Alpes, CITI - CITI Centre of Innovation in Telecommunications and Integration of services
Abstract : The Forward Error Correction (FEC) Framework (or FECFRAME) (RFC 6363) has been defined by the FECFRAME IETF WG to enable the use of FEC Encoding with real-time flows in a flexible manner. The original FECFRAME specification only considers the use of block FEC codes, wherein the input flow(s) is(are) segmented into a sequence of blocks and FEC encoding performed independently on a per-block basis. This document discusses an extension of FECFRAME in order to enable a sliding (potentially elastic) window encoding of the input flow(s), using convolutional FEC codes for the erasure channel, as an alternative to block FEC codes.
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/hal-01141470
Contributor : Vincent Roca <>
Submitted on : Tuesday, May 24, 2016 - 11:04:38 AM
Last modification on : Wednesday, July 8, 2020 - 12:43:27 PM
File
draft-roca-nwcrg-fecframev2-pr...
Identifiers
  • HAL Id : hal-01141470, version 3
Collections
Citation
Vincent Roca. FECFRAMEv2: Adding Sliding Encoding Window Capabilities to the FEC Framework: Problem Position. 2016, pp.18. ⟨hal-01141470v3⟩
Share
Metrics
Record views
240
Files downloads
366
