Journal articles
Visibility-driven progressive volume photon tracing
Abstract : In this paper, we present a novel approach to progressive photon-based volume rendering techniques. By making use of two Kd-trees (built in a preprocessing step) to store view beams (primary rays intersecting the medium) and visible points, our method allows to handle scenes with specular and refractive objects as well as homogeneous and heterogeneous participating media and does not require the storage of photon maps, which solves the memory management issue. These data structures are used to drive the photon shooting process by considering the photon visibility as an importance function (similarly to Hachisuka and Jensen in ACM Trans. Graph. 30(5):114:1–114:11, 2011) for scenes containing participating media. Finally, we demonstrate that our method can be easily combined with the most recent particle tracing approaches such as the one presented in Jarosz et al. (ACM Trans. Graph., vol. 30(6), 2011).
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01141843
Contributor : Rémi Cozot Connect in order to contact the contributor
Submitted on : Monday, April 13, 2015 - 9:48:44 PM
Last modification on : Wednesday, December 22, 2021 - 11:58:05 AM
Links full text
Identifiers
Citation
Charly Collin, Mickaël Ribardière, Adrien Gruson, Rémi Cozot, Sumanta Pattanaik, et al.. Visibility-driven progressive volume photon tracing. The Visual Computer, Springer Verlag, 2013, 29 (9), pp.849-859. ⟨10.1007/s00371-013-0845-x⟩. ⟨hal-01141843⟩
Share
Metrics
Record views
220
