New interface
Conference papers
Automatic Aesthetics-based Lighting Design with Global Illumination
Abstract : In computer graphics, lighting plays an important role in the appearance of a scene. A change in the configuration of light sources can lead to different aesthetics in the final rendered image. Lighting design becomes increasingly complex when using sophisticated global illumination techniques. In this paper, we present a new approach to automatically design the lighting configuration according to the aesthetic goal specified by the user as a set of target parameters. Target parameters are used to set up an objective function which is minimized using an optimization method. The results show that our method can be used to automatically design a lighting configuration that will give to the final image a classic photographic look.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01141848
Contributor : Rémi Cozot Connect in order to contact the contributor
Submitted on : Monday, April 13, 2015 - 11:11:48 PM
Last modification on : Monday, June 27, 2022 - 3:01:58 AM
Identifiers
Citation
Vincent Léon, Adrien Gruson, Rémi Cozot, Kadi Bouatouch. Automatic Aesthetics-based Lighting Design with Global Illumination. Pacific Graphics, 2014, Séoul, South Korea. ⟨10.2312/pgs.20141256⟩. ⟨hal-01141848⟩
Share
Metrics
Record views
141
