Optimizing Reformulation-based Query Answering in RDF - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Reformulation-based query answering is a query processing technique aiming at answering queries under constraints. It consists of reformulating the query based on the constraints, so that evaluating the reformulated query directly against the data (i.e., without considering any more the constraints) produces the correct answer set. In this paper, we consider optimizing reformulation-based query answering in the setting of ontology-based data access, where SPARQL conjunctive queries are posed against RDF facts on which constraints expressed by an RDF Schema hold. The literature provides query reformulation algorithms for many fragments of RDF. However, reformulated queries may be complex, thus may not be efficiently processed by a query engine; well established query engines even fail processing them in some cases. Our contribution is (i) to generalize prior query reformu-lation languages, leading to investigating a space of refor-mulated queries we call JUCQs (joins of unions of conjunctive queries), instead of a single reformulation; and (ii) an effective and efficient cost-based algorithm for selecting from this space, the reformulated query with the lowest estimated cost. Our experiments show that our technique enables reformulation-based query answering where the state-of-the-art approaches are simply unfeasible, while it may decrease its cost by orders of magnitude in other cases.
paper-88.pdf (728.29 Ko) Télécharger le fichier
hal-01143068 , version 1 (16-04-2015)
  • HAL Id : hal-01143068 , version 1
Damian Bursztyn, François Goasdoué, Ioana Manolescu. Optimizing Reformulation-based Query Answering in RDF. EDBT: 18th International Conference on Extending Database Technology, Mar 2015, Brussels, Belgium. ⟨hal-01143068⟩
581 Consultations
234 Téléchargements
