Perfusion MRI Deconvolution with Delay Estimation and Non-Negativity Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Perfusion MRI deconvolution aims to recover the time-dependent residual amount of indicator (residue function) from the measured arterial and tissue concentration time-curves. The deconvolution is complicated by the presence of a time lag between the measured concentrations. Moreover the residue function must be non-negative and its shape may become non-monotonic due to dispersion phenomena. We introduce Modified Exponential Bases (MEB) to perform de-convolution. The MEB generalize the previously proposed exponential approximation (EA) by taking into account the time lag and introducing non-negativity constraints for the recovered residue function also in the case of non-monotonic dispersed shapes, thus overcoming the limitation due to the non-increasing assumtion of the EA. The deconvolution problem is solved linearly. Quantitative comparisons with the widespread block-circulant Singular Value Decomposition show favorable results in recovering the residue function.
root.pdf (2.45 Mo) Télécharger le fichier
hal-01143213 , version 1 (16-04-2015)
Marco Pizzolato, Aurobrata Ghosh, Timothé Boutelier, Rachid Deriche. Perfusion MRI Deconvolution with Delay Estimation and Non-Negativity Constraints. International Symposium on Biomedical Imaging, Apr 2015, Brooklyn, New York, United States. ⟨10.1109/ISBI.2015.7164057⟩. ⟨hal-01143213⟩
186 Consultations
325 Téléchargements
