On the Combination of Silent Error Detection and Checkpointing, 2013 IEEE 19th Pacific Rim International Symposium on Dependable Computing, pp.11-20, 2013. ,
DOI : 10.1109/PRDC.2013.10
URL : https://hal.archives-ouvertes.fr/hal-00836871
Detecting silent data corruption through data dynamic monitoring for scientific applications, SIGPLAN Notices, vol.49, issue.8, pp.381-382, 2014. ,
Assessing general-purpose algorithms to cope with fail-stop and silent errors, Proceedings of the 5th International Workshop on Performance Modeling, Benchmarking and Simulation of High Performance Computer Systems (PMBS) held as part of Supercomputing (SC), 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01358146
Efficient checkpoint/verification patterns for silent error detection, 2014. ,
Silent error detection in numerical time-stepping schemes, International Journal of High Performance Computing Applications, vol.29, issue.4, pp.10-1177, 2014. ,
DOI : 10.1177/1094342014532297
Algorithm-based fault tolerance applied to high performance computing, Journal of Parallel and Distributed Computing, vol.69, issue.4, pp.410-416, 2009. ,
DOI : 10.1016/j.jpdc.2008.12.002
Soft error vulnerability of iterative linear algebra methods, Proceedings of the 22nd annual international conference on Supercomputing , ICS '08, pp.155-164, 2008. ,
DOI : 10.1145/1375527.1375552
Distributed snapshots: determining global states of distributed systems, ACM Transactions on Computer Systems, vol.3, issue.1, pp.63-75, 1985. ,
DOI : 10.1145/214451.214456
Online-ABFT: An online algorithm based fault tolerance scheme for soft error detection in iterative methods, Proceedings of the ACM SIGPLAN Symposium on Principles and Practice of Parallel Programming (PPoPP), pp.167-176, 2013. ,
Application-level fault tolerance in the orbital thermal imaging spectrometer, 10th IEEE Pacific Rim International Symposium on Dependable Computing, 2004. Proceedings., pp.43-48, 2004. ,
DOI : 10.1109/PRDC.2004.1276551
A higher order estimate of the optimum checkpoint interval for restart dumps, Future Generation Computer Systems, vol.22, issue.3, pp.303-312, 2006. ,
DOI : 10.1016/j.future.2004.11.016
The International Exascale Software Project: a Call To Cooperative Action By the Global High-Performance Community, International Journal of High Performance Computing Applications, vol.23, issue.4, pp.309-322, 2009. ,
DOI : 10.1177/1094342009347714
Explicit inverses of Toeplitz and associated matrices, ANZIAM Journal, vol.44, issue.E, pp.185-215, 2003. ,
DOI : 10.21914/anziamj.v44i0.493
Combining Partial Redundancy and Checkpointing for HPC, 2012 IEEE 32nd International Conference on Distributed Computing Systems, pp.615-626, 2012. ,
DOI : 10.1109/ICDCS.2012.56
A survey of rollback-recovery protocols in message-passing systems, ACM Computing Surveys, vol.34, issue.3, pp.375-408, 2002. ,
DOI : 10.1145/568522.568525
Detection and correction of silent data corruption for large-scale high-performance computing, Proc. SC'12, p.78, 2012. ,
Fault-tolerant iterative methods via selective reliability, Research report SAND2011-3915 C, Sandia National Laboratories, 2011. ,
Algorithm-based fault tolerance for matrix operations, IEEE Trans. Comput, vol.33, issue.6, pp.518-528, 1984. ,
Fault tolerant matrix operations on multiple systems using weighted checksums, Proc. SPIE 0495, Real-Time Signal Processing VII, pp.94-101, 1984. ,
When is multi-version checkpointing needed?, Proceedings of the 3rd Workshop on Fault-tolerance for HPC at extreme scale, FTXS '13, pp.49-56, 2013. ,
DOI : 10.1145/2465813.2465821
The Use of Triple-Modular Redundancy to Improve Computer Reliability, IBM Journal of Research and Development, vol.6, issue.2, pp.200-209, 1962. ,
DOI : 10.1147/rd.62.0200
Design, Modeling, and Evaluation of a Scalable Multi-level Checkpointing System, Proc. of the ACM, pp.1-11, 2010. ,
ACR, Proceedings of the International Conference for High Performance Computing, Networking, Storage and Analysis on, SC '13, 2013. ,
DOI : 10.1145/2503210.2503266
The effect of cosmic rays on the soft error rate of a DRAM at ground level, IEEE Transactions on Electron Devices, vol.41, issue.4, pp.553-557, 1994. ,
DOI : 10.1109/16.278509
Self-stabilizing iterative solvers, Proceedings of the Workshop on Latest Advances in Scalable Algorithms for Large-Scale Systems, ScalA '13, 2013. ,
DOI : 10.1145/2530268.2530272
Fault tolerant preconditioned conjugate gradient for sparse linear system solution, Proceedings of the 26th ACM international conference on Supercomputing, ICS '12, pp.69-78, 2012. ,
DOI : 10.1145/2304576.2304588
A first order approximation to the optimum checkpoint interval, Communications of the ACM, vol.17, issue.9, pp.530-531, 1974. ,
DOI : 10.1145/361147.361115
IBM experiments in soft fails in computer electronics (1978???1994), IBM Journal of Research and Development, vol.40, issue.1, pp.3-18, 1996. ,
DOI : 10.1147/rd.401.0003
