Some Results on Distribution-Free Analysis of Paging Algorithms, IEEE Transactions on Computers, vol.25, issue.7, pp.737-745, 1976. ,
DOI : 10.1109/TC.1976.1674682
Stochastic Analysis of Computer Storage, 1987. ,
Two-Level Replacement Decisions in Paging Stores, IEEE Transactions on Computers, vol.32, issue.12, pp.1151-1159, 1983. ,
DOI : 10.1109/TC.1983.1676176
A class of mean field interaction models for computer and communication systems, Performance Evaluation, vol.65, pp.11-12823, 2008. ,
Exact analysis of TTL cache networks, Performance Evaluation, vol.79, pp.2-23, 2014. ,
DOI : 10.1016/j.peva.2014.07.001
The stationary behaviour of fluid limits of reversible processes is concentrated on stationary points, Networks and Heterogeneous Media, vol.8, issue.2, 2010. ,
DOI : 10.3934/nhm.2013.8.529
Web caching and Zipf-like distributions: evidence and implications, IEEE INFOCOM '99. Conference on Computer Communications. Proceedings. Eighteenth Annual Joint Conference of the IEEE Computer and Communications Societies. The Future is Now (Cat. No.99CH36320), pp.126-134, 1999. ,
DOI : 10.1109/INFCOM.1999.749260
Hierarchical Web caching systems: modeling, design and experimental results, IEEE Journal on Selected Areas in Communications, vol.20, issue.7, pp.1305-1314, 2002. ,
DOI : 10.1109/JSAC.2002.801752
An approximate analysis of the LRU and FIFO buffer replacement schemes, ACM SIGMETRICS Performance Evaluation Review, vol.18, issue.1, pp.143-152, 1990. ,
DOI : 10.1145/98460.98525
Efficient Calculation of Expected Miss Ratios in the Independent Reference Model, SIAM Journal on Computing, vol.7, issue.3, pp.288-296, 1978. ,
DOI : 10.1137/0207025
Analysis of TTL-based cache networks, Valuetools 2012, pp.1-10, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00676735
Correlation inequalities on some partially ordered sets, Communications in Mathematical Physics, vol.26, issue.Suppl., pp.89-103, 1971. ,
DOI : 10.1007/BF01651330
A versatile and accurate approximation for lru cache performance, Proceedings of the 24th International Teletraffic Congress, ITC '12, pp.1-8, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00671937
Performance evaluation of the random replacement policy for networks of caches, Performance Evaluation, issue.0, pp.7216-7252, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01137898
A Unified Approach to the Evaluation of a Class of Replacement Algorithms, IEEE Transactions on Computers, vol.22, issue.6, pp.611-618, 1973. ,
DOI : 10.1109/TC.1973.5009115
Self-organizing linear search, ACM Computing Surveys, vol.17, issue.3, pp.295-311, 1985. ,
DOI : 10.1145/5505.5507
Analysis of Page Replacement Policies in the Fluid Limit, Operations Research, vol.58, issue.4-part-1, pp.971-984, 2010. ,
DOI : 10.1287/opre.1090.0761
Asymptotic approximation of the move-to-front search cost distribution and least-recently used caching fault probabilities, The Annals of Applied Probability, vol.9, issue.2, pp.430-464, 1999. ,
DOI : 10.1214/aoap/1029962750
LIRS, ACM SIGMETRICS Performance Evaluation Review, vol.30, issue.1, pp.31-42, 2002. ,
DOI : 10.1145/511399.511340
2Q: A low overhead high performance buffer management replacement algorithm, VLDB '94, pp.439-450, 1994. ,
Modeling TTL-based Internet caches, IEEE INFOCOM 2003. Twenty-second Annual Joint Conference of the IEEE Computer and Communications Societies (IEEE Cat. No.03CH37428), pp.417-426, 2003. ,
DOI : 10.1109/INFCOM.2003.1208693
Analysis of demand paging algorithms, In IFIP Congress, issue.1, pp.485-490, 1971. ,
The LCD interconnection of LRU caches and its analysis, Performance Evaluation, vol.63, issue.7, pp.609-634, 2006. ,
DOI : 10.1016/j.peva.2005.05.003
Inequalities: theory of majorization and its applications, 1979. ,
DOI : 10.1007/978-0-387-68276-1
A unified approach to the performance analysis of caching systems, IEEE INFOCOM 2014, IEEE Conference on Computer Communications, pp.2040-2048, 2014. ,
DOI : 10.1109/INFOCOM.2014.6848145
Approximate Models for General Cache Networks, 2010 Proceedings IEEE INFOCOM, pp.1100-1108, 2010. ,
DOI : 10.1109/INFCOM.2010.5461936
Probabilistic methods for web caching, Performance Evaluation, vol.46, issue.2-3, pp.125-137, 2001. ,
DOI : 10.1016/S0166-5316(01)00045-1
Fluid limit analysis of FIFO and RR caching for independent reference models, Performance Evaluation, vol.69, issue.9, pp.403-412, 2012. ,
DOI : 10.1016/j.peva.2012.05.008
LRU is better than FIFO under the independent reference model, Journal of Applied Probability, vol.2, issue.01, pp.239-243, 1992. ,
DOI : 10.1017/S0305004100034241
Properties of the miss ratio for a 2-level storage model with LRU or FIFO replacement strategy and independent references, IEEE Transactions on Computers, vol.42, issue.4, pp.508-512, 1993. ,
DOI : 10.1109/12.214697
Comparing strength of locality of reference - popularity, majorization, and some folk theorems, IEEE INFOCOM 2004, 2004. ,
DOI : 10.1109/INFCOM.2004.1356972
The output of a cache under the independent reference model, ACM SIGMETRICS Performance Evaluation Review, vol.32, issue.1, pp.295-306, 2004. ,
DOI : 10.1145/1012888.1005722
A framework for uplink power control in cellular radio systems. Selected Areas in Communications, IEEE Journal on, vol.13, issue.7, pp.1341-1347, 1995. ,
Characteristics of YouTube network traffic at a campus network ??? Measurements, models, and implications, Computer Networks, vol.53, issue.4, pp.501-514, 2009. ,
DOI : 10.1016/j.comnet.2008.09.022
