Journal articles
Dispersion and Collapse in Stochastic Velocity Fields on a Cylinder
Abstract : The dynamics of fluid particles on cylindrical manifolds is investigated. The velocity field is obtained by generalizing the isotropic Kraichnan ensemble, and is therefore Gaussian and decorrelated in time. The degree of compressibility is such that when the radius of the cylinder tends to infinity the fluid particles separate in an explosive way. Nevertheless, when the radius is finite the transition probability of the two-particle separation converges to an invariant measure. This behavior is due to the large-scale compressibility generated by the compactification of one dimension of the space.
Complete list of metadata
https://hal.inria.fr/hal-01144168
Contributor : Sylvain Rubenthaler <>
Submitted on : Tuesday, April 21, 2015 - 10:38:07 AM
Last modification on : Monday, October 12, 2020 - 2:28:05 PM
Links full text
Identifiers
Collections
Citation
Dario Vincenzi, Antonio Celani. Dispersion and Collapse in Stochastic Velocity Fields on a Cylinder. Journal of Statistical Physics, Springer Verlag, 2010, 138 (4-5), pp.579-597. ⟨10.1007/s10955-009-9875-1⟩. ⟨hal-01144168⟩
Share
Metrics
Record views
229
