New interface
Conference papers
Impacts of the Packet Scheduling on the Performance of Erasure Codes: Methodology and Application to GLDPC-Staircase Codes
Ferdaouss Mattoussi 1 Vincent Roca 1 Bessem Sayadi 2
1 PRIVATICS - Privacy Models, Architectures and Tools for the Information Society
Inria Grenoble - Rhône-Alpes, CITI - CITI Centre of Innovation in Telecommunications and Integration of services, Inria Lyon
Abstract : Content broadcasting over wireless networks heavily relies on Application-Level FEC codes to improve transmission robustness in front of channel erasures. Because they operate in the higher layers of the protocol stack, they benefit from a lot of flexibility. In particular, since streaming applications and bulk transfer applications have different constraints, different packet scheduling strategies may be used by the sender, offering different trade-offs between decoding latency and long erasure burst protection. This work tries to find the best packet scheduling scheme(s) at a sender for a given type of AL-FEC codes. The contributions are twofold: first we define a methodology to measure the impacts of packet scheduling on AL-FEC performance , both under ITerative (IT) and Maximum Likelihood (ML) decoding, for a large set of channels; then we apply this methodology to GLDPC-Staircase codes, an extension of LDPC-Staircase codes using Reed Solomon codes as inner codes. In previous works we showed that these codes have erasure recovery performance close to ideals codes when packets are transmitted in a random order. In this work we show that these codes perform extremely well when sending source packets sequentially first (a key requirement to keep latency minimum with streaming applications) and then extra-repair packets followed by LDPC repair packets, both in a random order.
Complete list of metadata
Cited literature [23 references]  Display  Hide  Download
https://hal.inria.fr/hal-01144380
Contributor : Vincent Roca Connect in order to contact the contributor
Submitted on : Tuesday, April 21, 2015 - 3:22:53 PM
Last modification on : Thursday, August 4, 2022 - 5:18:35 PM
Long-term archiving on: : Wednesday, April 19, 2017 - 2:27:28 AM
File
gldpc_staircase_codes_vs_trans...
Identifiers
  • HAL Id : hal-01144380, version 1
Collections
Citation
Ferdaouss Mattoussi, Vincent Roca, Bessem Sayadi. Impacts of the Packet Scheduling on the Performance of Erasure Codes: Methodology and Application to GLDPC-Staircase Codes. IEEE European Conference on Networks and Communications (EUCNC'15), Nicolas Demassieux and Mário Campolargo, EUCNC 2015 Chairs, Jun 2015, Paris, France. ⟨hal-01144380⟩
Share
Metrics
Record views
130
Files downloads
145
