D. Mackay and R. Neal, Near Shannon limit performance of low density parity check codes, Electronics Letters, vol.33, issue.6, pp.457-458, 1997.
DOI : 10.1049/el:19970362
R. Tanner, A recursive approach to low complexity codes, IEEE Transactions on Information Theory, vol.27, issue.5, pp.533-547, 1981.
DOI : 10.1109/TIT.1981.1056404
J. Boutros, O. Pothier, and G. Zémor, Generalized low density (Tanner) codes, 1999 IEEE International Conference on Communications (Cat. No. 99CH36311), 1999.
DOI : 10.1109/ICC.1999.767979
M. Lentmaier and K. Zigangirov, On generalized low-density parity-check codes based on Hamming component codes, IEEE Communications Letters, vol.3, issue.8, pp.248-250, 1999.
DOI : 10.1109/4234.781010
G. Yue, L. Ping, and X. Wang, Generalized Low-Density Parity-Check Codes Based on Hadamard Constraints, IEEE Transactions on Information Theory, vol.53, issue.3, pp.1058-1079, 2007.
DOI : 10.1109/TIT.2006.890694
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.96.6891
J. Chen and R. Tanner, A hybrid coding scheme for the Gilbert-Elliott channel, IEEE Transactions on Communications, vol.54, issue.10, pp.1787-1796, 2006.
DOI : 10.1109/TCOMM.2006.881365
N. Miladinovic and M. Fossorier, Generalized LDPC codes with Reed-Solomon and BCH codes as component codes for binary channels, GLOBECOM '05. IEEE Global Telecommunications Conference, 2005., 2005.
DOI : 10.1109/GLOCOM.2005.1577850
I. Djordjevic, O. Milenkovic, and B. Vasic, Generalized low-density parity-check codes for optical communication systems, Journal of Lightwave Technology, vol.23, issue.5, pp.1939-1946, 2005.
DOI : 10.1109/JLT.2005.846892
Y. Wang and M. Fossorier, Doubly Generalized LDPC Codes, 2006 IEEE International Symposium on Information Theory, pp.669-673, 2006.
DOI : 10.1109/ISIT.2006.261869
URL : https://hal.archives-ouvertes.fr/hal-00865899
E. Paolini, M. Fossorier, and M. Chiani, Analysis of Doubly- Generalized LDPC Codes with Random Component Codes for the Binary Erasure Channel, Proceedings of Allerton Conference on Communications , Control and Computing, 2006.
F. Mattoussi, V. Roca, and B. Sayadi, Design of small rate, close to ideal, GLDPC-staircase AL-FEC codes for the erasure channel, 2012 IEEE Global Communications Conference (GLOBECOM), 2012.
DOI : 10.1109/GLOCOM.2012.6503433
URL : https://hal.archives-ouvertes.fr/hal-00736071
V. Roca, C. Neumann, and D. Furodet, Low density parity check (ldpc) staircase and triangle forward error correction (fec) schemes, IETF Request for Comments, vol.5170, 2008.
DOI : 10.17487/rfc5170
URL : https://hal.archives-ouvertes.fr/inria-00000147
M. Luby, J. Gemmell, L. Vicisano, L. Rizzo, and J. Crowcroft, Asynchronous layered coding (alc) protocol instantiation, IETF Request for Comment, vol.3450, 2002.
T. Paila, M. Luby, R. Lehtonen, V. Roca, and R. Walsh, Flute -file delivery over unidirectional transport, IETF Request for Comments, vol.3926, 2004.
URL : https://hal.archives-ouvertes.fr/hal-00749951
V. Roca, M. Cunche, C. Thienot, J. Detchart, and J. Lacan, RS + LDPC-Staircase codes for the erasure channel: Standards, usage and performance, 2013 IEEE 9th International Conference on Wireless and Mobile Computing, Networking and Communications (WiMob), 2013.
DOI : 10.1109/WiMOB.2013.6673424
M. Luby, A. Shokrollahi, M. Watson, and T. Stockhammer, Raptor Forward Error Correction Scheme for Object Delivery, IETF Request for Comments, RFC, vol.5053, 2007.
DOI : 10.17487/rfc5053
M. Luby, A. Shokrollahi, M. Watson, T. Stockhammer, and L. Minder, RaptorQ Forward Error Correction Scheme for Object Delivery, IETF Request for Comments, vol.6330, 2011.
DOI : 10.17487/rfc6330
E. N. Gilbert, Capacity of a Burst-Noise Channel, Bell System Technical Journal, vol.39, issue.5, p.12531266, 1960.
DOI : 10.1002/j.1538-7305.1960.tb03959.x
J. Bolot and A. V. Garcia, The case for fec-based error control for packet audio in the internet, ACM Int. Conference of Multimedia, 1996.
H. Sanneck, G. Carle, and R. Koodli, A framework model for packet loss metrics based on loss runlength, SPIE/ACM SIGMM Multimedia Computing Network Conference, 2000.
C. C. Tan and N. C. Beaulieu, On first-order Markov modeling for the Rayleigh fading channel, IEEE Transactions on Communications, vol.48, issue.12, pp.2032-2040, 1963.
DOI : 10.1109/26.891214
F. Mattoussi, V. Roca, and B. Sayadi, Optimization with exit functions of GLDPC-Staircase codes for the BEC, 2012 IEEE 13th International Workshop on Signal Processing Advances in Wireless Communications (SPAWC), 2012.
DOI : 10.1109/SPAWC.2012.6292979
URL : https://hal.archives-ouvertes.fr/hal-00719321
F. Mattoussi, B. Sayadi, and V. Roca, Good coupling between LDPC-staircase and Reed-Solomon for the design of GLDPC codes for the erasure channel, 2013 IEEE Wireless Communications and Networking Conference (WCNC), 2013.
DOI : 10.1109/WCNC.2013.6554790
URL : https://hal.archives-ouvertes.fr/hal-00781921
