On the smoothed complexity of convex hulls
We establish an upper bound on the smoothed complexity of convex
hulls in $\mathbb{R}^d$ under uniform Euclidean ($\ell^2$) noise.
Specifically, let $\{p_1^*, p_2^*, \ldots, p_n^*\}$ be an arbitrary
set of $n$ points in the unit ball in $\mathbb{R}^d$ and let
$p_i=p_i^*+x_i$, where $x_1, x_2, \ldots, x_n$ are chosen
independently from the unit ball of radius $\delta$. We show that
the expected complexity, measured as the number of faces of all
dimensions, of the convex hull of $\{p_1,p_2, \ldots, p_n\}$ is
$O\left(n^{2-\frac{4}{d+1}}\left(1+1/\delta\right)^{d-1}\right)$; the magnitude
$\delta$ of the noise may vary with $n$. For $d=2$ this bound
improves to $O\left(n^{\frac{2}{3}}(1+\delta^{-\frac{2}{3}}\right)$.
We also analyze the expected complexity of the convex hull of
$\ell^2$ and Gaussian perturbations of a nice sample of a sphere,
giving a lower-bound for the smoothed complexity. We identify the
different regimes in terms of the scale, as a function of $n$, and
show that as the magnitude of the noise increases, that complexity
varies monotonically for Gaussian noise but non-monotonically for
$\ell^2$ noise.
Géométrie algorithmique [cs.CG]
socg-final.pdf (984.2 Ko)
Télécharger le fichier
vignette (1).jpg (10.5 Ko)
vignette (1).png (22.37 Ko)
Format : Figure, Image
