The mathematical theory of reduced MHD models for fusion plasmas - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
Théorie mathématique des modèles de MHD r\éduite pour les plasmas de fusion
The derivation of reduced MHD models for fusion plasma is here formulated as a special instance of the general theory of singular limit of hyperbolic system of PDEs with large operator. This formulation allows to use the general results of this theory and to prove rigorously that reduced MHD models are valid approximations of the full MHD equations. In particular, it is proven that the solutions of the full MHD system converge to the solutions of an appropriate reduced model
RR-8715.pdf (722.42 Ko) Télécharger le fichier
hal-01145009 , version 1 (02-06-2015)
Hervé Guillard. The mathematical theory of reduced MHD models for fusion plasmas. [Research Report] RR-8715, INRIA. 2015. ⟨hal-01145009⟩
610 Consultations
217 Téléchargements
