A minicourse on the low Mach number limit. Discrete and Continuous Dynamical Systems series S, pp.365-404, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00535104
Problems with Different Time Scales for Nonlinear Partial Differential Equations, SIAM Journal on Applied Mathematics, vol.42, issue.4, pp.704-718, 1982. ,
DOI : 10.1137/0142049
Effects of toroidal coupling on the stability of tearing modes, Physics of Fluids, vol.24, issue.1, pp.66-77, 1981. ,
DOI : 10.1063/1.863247
B??zier surfaces and finite elements for MHD simulations, Journal of Computational Physics, vol.227, issue.16, pp.7423-7445, 2008. ,
DOI : 10.1016/j.jcp.2008.04.001
Non-convex entropies for conservation laws with involutions, Philosophical Transactions of The Royal Society A Mathematical Physical and Engineering Sciences, vol.371, p.371, 2005. ,
Reduced resistive MHD in Tokamaks with general density, ESAIM: Mathematical Modelling and Numerical Analysis, vol.46, issue.5, pp.1081-1106 ,
DOI : 10.1051/m2an/2011078
Nonlinear reduced fluid equations for toroidal plasmas, Physics of Fluids, vol.27, issue.4, 1958. ,
DOI : 10.1063/1.864680
Energy conservation and numerical stability for the reduced MHD models of the non-linear JOREK code, ESAIM: Mathematical Modelling and Numerical Analysis, vol.49, issue.5, p.2, 2015. ,
DOI : 10.1051/m2an/2015014
URL : https://hal.archives-ouvertes.fr/hal-01053713
Nonlinear magnetohydrodynamics simulation using high-order finite elements, Journal of Computational Physics, vol.195, p.355, 2004. ,
Magnetohydrodynamic Wavesand Instabilities in Rotating Tokamak Plasmas, 2013. ,
Shear-Alfv??n dynamics of toroidally confined plasmas, Physics Reports, vol.121, issue.1-2, pp.1-164, 1985. ,
DOI : 10.1016/0370-1573(85)90083-3
Reduced equations for internal kinks in tokamaks, Physics of Fluids, vol.26, issue.10, pp.3066-3069, 1983. ,
DOI : 10.1063/1.864030
The M3DC1 approach to simulating 3D 2-fluid magnetohydrodynamics in magnetic fusion experiments, Journal of Physics: Conference Series, 2008. ,
Compressible and incompressible fluids, Communications on Pure and Applied Mathematics, vol.33, issue.5, pp.629-653, 1982. ,
DOI : 10.1002/cpa.3160350503
Singular limits of quasilinear hyperbolic systems with large parameters and the incompressible limit of compressible fluids, Communications on Pure and Applied Mathematics, vol.71, issue.4, pp.481-524, 1981. ,
DOI : 10.1002/cpa.3160340405
Problems with different time scales for partial differential equations, Communications on Pure and Applied Mathematics, vol.116, issue.3, pp.399-440, 1980. ,
DOI : 10.1002/cpa.3160330310
Generalized reduced magnetohydrodynamic equations, Physics of Plasmas, vol.5, issue.12, pp.4169-4182, 1998. ,
DOI : 10.1063/1.873152
URL : http://www.osti.gov/scitech/servlets/purl/314121
Hyperbolic Systems of Conservation Laws and the Mathematical Theory of Shock Waves, 1973. ,
Compressible Fluid Flow and Systems of Conservation Laws in Several Space Variables, Applied Mathematical Sciences, vol.53 ,
DOI : 10.1007/978-1-4612-1116-7
Hamiltonian formulation of reduced magnetohydrodynamics, Physics of Fluids, vol.27, issue.4, pp.886-97, 1984. ,
DOI : 10.1063/1.864718
Simulation of plasma turbulence in scrape-off layer conditions: the GBS code, simulation results and code validation, Plasma Physics and Controlled Fusion, vol.54, issue.12, p.54124047, 2012. ,
DOI : 10.1088/0741-3335/54/12/124047
Reduced, three-dimensional, nonlinear equations for high-?? plasmas including toroidal effects, Physics Letters A, vol.82, issue.1, pp.14-17, 1981. ,
DOI : 10.1016/0375-9601(81)90388-1
Symmetric hyperbolic systems with a large parameter, Communications in Partial Differential Equations, vol.11, issue.15, pp.1627-1651, 1986. ,
DOI : 10.1007/BF01229377
Asymptotics for symmetric hyperbolic systems with a large parameter, Journal of Differential Equations, vol.75, issue.1, pp.1-27, 1988. ,
DOI : 10.1016/0022-0396(88)90126-X
Fast Singular Limits of Hyperbolic PDEs, Journal of Differential Equations, vol.114, issue.2, pp.476-512, 1994. ,
DOI : 10.1006/jdeq.1994.1157
Drift-ordered fluid equations for modelling collisional edge plasma, Contributions to Plasma Physics, vol.44, issue.13, pp.83-94, 2004. ,
DOI : 10.1002/ctpp.200410012
Nonlinear, three-dimensional magnetohydrodynamics of noncircular tokamaks, Physics of Fluids, vol.19, issue.1, p.134, 1976. ,
DOI : 10.1063/1.861310
Dynamics of high ?? tokamaks, Physics of Fluids, vol.20, issue.8, p.1354, 1977. ,
DOI : 10.1063/1.862018
Reduced MHD in nearly potential magnetic fields, Journal of Plasma Physics, vol.57, issue.1, pp.83-87, 1997. ,
DOI : 10.1017/S0022377896005296
Nonlinear reduced Braginskii equations with ion thermal dynamics in toroidal plasma, Physics of Plasmas, vol.4, issue.6, 1997. ,
DOI : 10.1063/1.872368
