Universal integral control: An approach based on mollifiers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2016
The Universal Integral Control, introduced in H.K. Khalil [6], is revisited by employing mollifiers instead of a high-gain observer for the differentiation of the output signal. The closed loop system is a classical functional differential equation with distributed delays on which standard Lyapunov arguments are applied to study the stability. Low-pass filtering capability of mollifiers is demonstrated for a high amplitude and rapidly oscillating noise. The controller is supported by numerical simulations.
Hal.pdf (540.15 Ko) Télécharger le fichier
hal-01145601 , version 1 (24-04-2015)
Samer Riachy, Denis Efimov, Mamadou Mboup. Universal integral control: An approach based on mollifiers. IEEE Transactions on Automatic Control, 2016, 61 (1), pp.16. ⟨10.1109/TAC.2015.2427631⟩. ⟨hal-01145601⟩
282 Consultations
298 Téléchargements
