Abstract : A popular approach to apprenticeship learning (AL) is to formulate it
as an inverse reinforcement learning (IRL) problem.
The MaxEnt-IRL algorithm successfully integrates the maximum entropy principle
into IRL and unlike its predecessors, it resolves the
ambiguity arising from the fact that a possibly large number of policies could
match the expert's behavior. In this paper, we study an AL setting in which in
addition to the expert's trajectories,
a number of unsupervised trajectories is available. We introduce MESSI,
a novel algorithm that combines MaxEnt-IRL
with principles coming from semi-supervised learning. In particular, MESSI
integrates the unsupervised data into
the MaxEnt-IRL framework using a pairwise penalty on trajectories. Empirical
results in a highway driving and grid-world
problems indicate that MESSI is able to take advantage of the unsupervised trajectories and improve the performance of
MaxEnt-IRL.
https://hal.inria.fr/hal-01146187
Contributor : Alessandro Lazaric <>
Submitted on : Monday, July 20, 2015 - 10:10:21 AM Last modification on : Friday, December 11, 2020 - 6:44:05 PM Long-term archiving on: : Wednesday, October 21, 2015 - 5:00:43 PM
