SRSC: SDN-based Routing Scheme for CCN - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Content delivery such as P2P or video streaming generates the main part of the Internet traffic and Content Centric Network (CCN) appears as an appropriate architecture to satisfy the user needs. However, the lack of scalable routing scheme is one of the main obstacles that slows down a large deployment of CCN at an Internet-scale. In this paper we propose to use the Software-Defined Networking (SDN) paradigm to decouple data plane and control plane and present SRSC, a new routing scheme for CCN. Our solution is a clean-slate approach using only CCN messages and the SDN paradigm. We implemented our solution into the NS-3 simulator and perform simulations of our proposal. SRSC shows better performances than the flooding scheme used by default in CCN: it reduces the number of messages, while still improves CCN caching performances.
Informatique
NetSoft-15_ElianV2.pdf (274.56 Ko) Télécharger le fichier
hal-01146457 , version 1 (28-04-2015)
Copyright (Tous droits réservés)
Elian Aubry, Thomas Silverston, Isabelle Chrisment. SRSC: SDN-based Routing Scheme for CCN. IEEE NetSoft, Apr 2015, Londres, United Kingdom. ⟨10.1109/NETSOFT.2015.7116130⟩. ⟨hal-01146457⟩
332 Consultations
784 Téléchargements
