Generation of Folded Terrains from Simple Vector Maps
Abstract : While several terrain generation methods focused on plausible watersheds, the fact that most mountains should not be isolated but rather be part of wider scale mountain ranges was seldom considered. In this work, we present the first procedural method that generates folded terrains from simple user input, in the form of some sparse peak distribution on a vector map. The key idea is to infer possible continental plates from this distribution and to use simplified plate tectonics to generate relevant terrain folds. The resulting terrain with large-scale folds, computed in real-time, can be further refined using standard erosion simulation. This leads to detailed terrains with plausible mountain ranges that match the peak distributions and main rivers specified on simple vector maps.
Type de document :
Communication dans un congrès
B. Bickel; T. Ritschel. Eurographics 2015 short paper proceedings, May 2015, Zurich, Switzerland. The Eurographics Association, pp.4, 〈10.2312/egsh.20151019〉
Liste complète des métadonnées
Littérature citée [9 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/hal-01147920
Contributeur : Arnaud Emilien <>
Soumis le : lundi 30 mai 2016 - 13:35:22
Dernière modification le : mercredi 11 avril 2018 - 01:58:17
Document(s) archivé(s) le : mercredi 31 août 2016 - 10:45:50
Fichier
2015__Michel__Generation_of_Fo...
Fichiers éditeurs autorisés sur une archive ouverte
Collections
Citation
Elie Michel, Arnaud Emilien, Marie-Paule Cani. Generation of Folded Terrains from Simple Vector Maps. B. Bickel; T. Ritschel. Eurographics 2015 short paper proceedings, May 2015, Zurich, Switzerland. The Eurographics Association, pp.4, 〈10.2312/egsh.20151019〉. 〈hal-01147920v2〉
Métriques
Consultations de la notice
868
Téléchargements de fichiers
242
