A Recursive Formulation for Constrained Mechanical System Dynamics: Part I. Open Loop Systems, Mechanics of Structures and Machines, vol.15, issue.3, pp.359-382, 1987. ,
DOI : 10.1177/027836498300200301
A very efficient algorithm for the simulation of robots and similar multibody systems without inversion of the mass matrix, IFAC/IFIP/IMACS Symposium, pp.95-100, 1986. ,
Robot dynamics: Equations and algorithms, IEEE Int. Conf. Robotics and Automation, pp.826-834, 2000. ,
Parallel o(log n) algorithms for computation of manipulator for- Figure 8: Influence of the relative joint acceleration error on the relative displacement error. As the precision enforced on the computation of the joint acceleration increases, the precision in the final configuration of the linkage expressed in the world frame increases as well. ward dynamics, IEEE Transactions on Robotics and Automation, vol.11, issue.3, p.389400, 1995. ,
The dynamical attitude equations for an n-body satellite, Journal of Astronautical Sciences, vol.12, 1965. ,
Efficient maintenance and self-collision testing for kinematic chains, Symposium on Computational Geometry, 2002. ,
Efficient computation of articulated-body inertias using successive axial screws, IEEE Trans. on Robotics and Automation, vol.11, pp.606-611, 1995. ,
A lie-group formulation of kinematics and dynamics of constrained mbs and its application to analytical mechanics, Multibody System Dynamics, vol.9, issue.442, pp.311-352, 2003. ,
Adaptive dynamics: Algorithms and analysis, 2005. ,
Spatial operator algebra for manipulator modelling and control, Int. J. Robotics Research, vol.10, issue.4, pp.371-381, 1991. ,
