DeepMatching: Hierarchical Deformable Dense Matching - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computer Vision Année : 2016
We introduce a novel matching algorithm, called DeepMatching, to compute dense correspondences between images. DeepMatching relies on a hierarchical, multi-layer, correlational architecture designed for matching images and was inspired by deep convolutional approaches. The proposed matching algorithm can handle non-rigid deformations and repetitive textures and efficiently determines dense correspondences in the presence of significant changes between images. We evaluate the performance of DeepMatching, in comparison with state-of-the-art matching algorithms, on the Mikolajczyk (Mikolajczyk et al. A comparison of affine region detectors, 2005), the MPI-Sintel (Butler et al. A naturalistic open source movie for optical flow evaluation, 2012) and the Kitti (Geiger et al. Vision meets robotics: The KITTI dataset, 2013) datasets. DeepMatching outperforms the state-of-the-art algorithms and shows excellent results in particular for repetitive textures. We also apply DeepMatching to the computation of optical flow, called DeepFlow, by integrating it in the large displacement optical flow (LDOF) approach of Brox and Malik (Large displacement optical flow: descriptor matching in variational motion estimation, 2011). Additional robustness to large displacements and complex motion is obtained thanks to our matching approach. DeepFlow obtains competitive performance on public benchmarks for optical flow estimation.
paper.pdf (9.24 Mo) Télécharger le fichier
fig2_fig_mem_perf.pdf (31.77 Ko) Télécharger le fichier
hal-01148432 , version 1 (04-06-2015)
hal-01148432 , version 2 (08-10-2015)
hal-01148432 , version 3 (31-05-2016)
Jerome Revaud, Philippe Weinzaepfel, Zaid Harchaoui, Cordelia Schmid. DeepMatching: Hierarchical Deformable Dense Matching. International Journal of Computer Vision, 2016, 120 (3), pp.300-323. ⟨10.1007/s11263-016-0908-3⟩. ⟨hal-01148432v3⟩
3030 Consultations
9176 Téléchargements
